06-06-2009, 06:29 PM | #1 |
Front spring stop adjustment
There is a a spring stop on the driver's side of my 4x4's and I would like to know where to set it. I believe that these did not originally come out on trucks but were added as a recall.
Attached is a picture of what I am calling a spring stop as it may go by another name. TIA, Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC Last edited by JimKshortstep4x4; 07-14-2009 at 12:52 PM. |
06-06-2009, 11:43 PM | #2 |
Grease Monkey
Re: Front spring stop adjustment
I hate those things. I don't have one on my truck, but I never had one on my truck. I'd say loose it.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
06-07-2009, 12:45 AM | #3 |
I could give you a demension if you need it, mine has the front and back ones
06-07-2009, 05:12 AM | #4 |
Thanks for the replies!
A dimension would be appreciated! Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
06-07-2009, 06:33 AM | #5 |
Since stock front springs are almost flat, the shackle moves very little during suspension flex. When the wheel travels up, the spring actually shortens. If you have changed to any kind of lift spring, you will likely have to move/eliminate that stop. You need to make sure that the shackle can not make contact with the stop under normal suspension flex.
Tim |
06-07-2009, 11:15 AM | #6 |
Tim,
Thanks for the reply. The spring contacts the stop just at times like when going over a dip. I have room to move them out for more clearance and will do that. I initially set up four of our 4x4's with 1/8"-3/16" clearance but they all contact the stop under some conditions. Jim
06-07-2009, 12:02 PM | #7 | |
The stop bracket is 1 5/16" off of the body mount bracket
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 06-07-2009 at 12:04 PM. |
06-07-2009, 05:49 PM | #8 |
jaros44sr,
Thanks for the measurement. I will move the stops backwards for more clearance. Jim
06-08-2009, 12:35 AM | #9 |
Anytime, glad I could help out
