Old 06-07-2009, 01:23 AM   #1
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Odd starting attempt...
While working on my truck this morning, I accidently left the key turned to the accessory position, stepped away about 30 ft from the truck and all of a sudden it attempted to start itself. I ran back to the truck jumped in and turned the key to the off position. Needless to say my heart was racing...
Has anyone heard of this? What could have caused this?
Since this happened I have been a little worried about leaving the battery hooked up. Should I be concerned? Obviously something isn't quite right.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 06-07-2009, 01:34 AM   #2
Indyuke
Re: Odd starting attempt...
Kinda had something like this happen to me a while ago. Went to start the truck, and it started like it was supposed to. But on returning the key to the on position, the starter kept spinning, but not because it was stuck.
Turning the key to any position didn't make a difference, the starter was still engaged with the engine running. Then all of sudden about 15-20 seconds later the stater disengaged and turned off. Thought I'd lose my starter.
The only thing I could conclude was a serious short in the ignition switch. Might be your issue as well.
Indyuke is offline   Reply With Quote
Old 06-07-2009, 08:48 AM   #3
LockDoc
The Older Generation
LockDoc's Avatar
I would tend to agree with Indyduke. Ignition switch is where I would start anyway. And yes, I would leave the battery unhooked until I got it sorted...
LockDoc
Leon
Old 06-07-2009, 08:58 AM   #4
Boog
laying low
Boog's Avatar
[Should I be concerned? ] Well yeah. It's not supposed to do that. I wouldn't want to have had my hands down in the front of the engine when it started turning over. That would leave a mark.... Is the ign switch an old one? Maybe a bit loose. Removing the + cable is def a good idea until you get it resolved.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 06-08-2009, 11:57 AM   #5
c0reDump
Shouldn't you remove the negative cable (not the + cable) ?
c0reDump is offline   Reply With Quote
Old 06-07-2009, 12:56 PM   #6
GruntMoanCough
GruntMoanCough's Avatar
Poltergeist........
My goal in life is to be as good a person as my dog already thinks I am - Unknown
GruntMoanCough is offline   Reply With Quote
Old 06-07-2009, 01:15 PM   #7
big_al_71
big_al_71's Avatar
Christine!!!!
I would not check but replace the ignition switch..
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 06-07-2009, 01:19 PM   #8
lolife99
67-72 parts collector,…
lolife99's Avatar
I agree,... ignition switch!
Keith
Convert to disc brakes.
Old 06-07-2009, 02:45 PM   #9
69halfton
69halfton's Avatar
aha boog, that made me laugh, not sure if it was supposed to be sarcastic, but it read that way to me
I have to agree, ignition switch,
or those dang shop elves again..
- Jason
If you can turn, Youre not going fast enough.
Favorite caption:
first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around..
..back when men were men.
69halfton is offline   Reply With Quote
Old 06-07-2009, 02:55 PM   #10
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Thanks for that boog...
I know it's something to be concerned with, so it looks like I will be replacing the ignition switch pretty soon.
Anyone have a recommendation for the part? Local parts supplier? Specialty shop (Classic Parts, LMC,...)?
-Nate
Old 06-07-2009, 06:33 PM   #11
LockDoc
LockDoc's Avatar
If you can find one local I think I would do that. Do you have a NAPA close? If so call them and see. I've had good luck with their elec. parts.
LockDoc
Leon
Old 06-07-2009, 07:01 PM   #12
mr48chev
mr48chev's Avatar
The good Napa should be this one
http://www.napaonline.com/MasterPage...Starter+Switch
It isn't inexpensive but it should be as good as any you can buy. They also sell one for about half that that price which is an ok switch.
Old 06-07-2009, 09:40 PM   #13
72BlckButy
Tot Roddin'
72BlckButy's Avatar
LockDoc
We do have a NAPA store in the area, so I will be calling them this week to see what they have in stock.
Thanks for the info mr48chev! I hope that I don't sound bad bad in asking, but why is the one switch better than the other? More for informational purposes than trying to save a few extra $$$...
-Nate
Old 06-07-2009, 10:51 PM   #14
LockDoc
LockDoc's Avatar
You would have to ask the counter person where each one is made. One might be US and one overseas. I haven't compared the two...
LockDoc
Leon
Old 06-08-2009, 07:15 AM   #15
mrein3
mrein3's Avatar
I would purchase the switch but also be prepared to replace the plug that plugs into the back of the switch. When I got my truck 15 years ago the wires were melted and spliced. I ordered a new switch and plug from LMC, connected everything properly, and never looked back.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
