SOLD
Location: Poorest state in America(Breaux Bridge,Louisiana)
Shim stud extensions
does anyone know if someone makes some extensions (for upper a-arms) to be able to add more length to the studs to be able to add more shim/spacers to get more positive camber??
i am maxed out on stud length and i need to get more positive camber at the ride height i want to be at. if no one makes some, i will have some made at a local machine shop. i have a pretty good desgin ideas ![]()
1966 CHEVY FLEETSIDE SOLD 11-29-9 TRUCK THREAD- http://http://67-72chevytrucks.com/vboard/showthread.php?t=301368&page=2 |
SOLD
Re: Shim stud extensions
anyone?
![]() Join Date: Apr 2005
I know what you're talking about, but I've never seen anything like that.
Moog makes an longer stud ... it isn't an "add on" extension as much as it is a replacement.
sorry, but I don't know the part number ... |
SOLD
are the factory ones made to be removed? i thought the were welded into place??
I'm just glad to be here!
They are pressed in and have a knurl under the head that holds it from turning when pressed in place. I took mine out with a 3 lb hammer and install new ones with the same hammer.
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
Bodydropped71
Just a bolt should work fine... right?
NO!!! Just a bolt will not work! You are betting your life and the lives of others on these bolts. Get the proper bolts!
Rule #1: If it's stupid but works, it's not stupid. |
I bought some from LMC and the ones shipped were longer than what I replaced - maybe someone else can chime in here but these look exactly like wheel studs for a rear axle to me - which are available in many different lengths and grades from suppliers like ARP etc and are pressed in same style - wheel studs would seem to me to be the same grade of fastner - especially something desinged for something with 2000+ rear wheel HP.
make sure your frame rails havent rolled in causing your negative camber.
#11 | |
Has anyone mentioned "off-set" upper control arm shafts? They move the upper control arm outward, eliminating the need for excessive shimming and the longer bolts. It's a much more stable situation, but it does cost more.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
#12 | |
Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
One day...
Thats cool i didnt know they made those bolts, guess i never really looked around though..
Ill have to remember those! |
Happy to be here
![]() Join Date: Mar 2000
Who sells them?
#15 |
Resistance is Futile
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#16 | |
I don't know for sure that they are available for this application. They are essentailly "crash parts" made as replacements where a frame is not pulled enough or at all for that matter. I just assumed that they would be made to fit these trucks, there are millions of them out there...
A quick search yeilded a MOOG part number K6184
