06-08-2009, 09:51 PM | #1 |
help with wheel hop
I have a 1971 lwb chevy. I recently installed a posi unit with 4/11's. Under heavy acceleration from a dead stop i experience wheel-hop. When the single trac rear-end was in the truck i did not have this problem. How can i fix this without using ladder bars? Thanks, Shawn
06-08-2009, 10:01 PM | #2 |
if they can make it so can I!
Re: help with wheel hop
you might could try some shims under the axle to change your pinion angle
06-08-2009, 10:03 PM | #3 |
Coils or leaf springs?
06-09-2009, 06:11 AM | #4 |
coil springs.
06-09-2009, 07:35 AM | #5 |
We used to put a poly air bag (air ride,firestone) in the right rear coil to take care of wheel hop.It didn't take a lot of air pressure,just add until it calms down.We also used good shocks,I used Bilstien 5150's.It worked on G bodies should work on our trucks.Best part is it was cheap fix.............Bob
1967 C20 Custom - 396/TH400 1968 GMC short step-350/M21 |
06-09-2009, 08:38 AM | #6 |
Redefining LowBudget
cheat a little add more air to your tires but this is going to lower your traction
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
06-09-2009, 09:56 AM | #7 |
Senior Moment
I had the same problem after I put the Detriot Locker in my truck. The simple fix was LESS tire pressure. I thought more would be better and it got worse. With 32 psi it hoped like a rabbit. At 28 it got better, At 25 NO HOP. I'm running 275-15's on the rear.454 / 350 , detroit Locker with 3;50 gears
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
06-09-2009, 05:00 PM | #8 |
its all about the +6 inches
the actual problem is probably in the bushings in the panhard bar and in the front of the trailing arms.
Those 6 foot (or so) long trailing arms work as traction bars, and there should be no wheel hop. |
06-09-2009, 05:07 PM | #9 |
Just Not Low Enough!
Agreed, i had the same problem, was the panhard bar bushing.
NEED ELECTRICAL HELP? ASK ME! 67-72 Full Wiring Diagrams Lots Of Info, TAKE A LOOK 1967 Chevy C-10 Shortbox Bagged 327 4spd Previous: 1971 Chevy C-10 Short Sep I6 Auto (Traded) 1973 Chevy C-20 *THE REDNECK BATTLE TRUCK* 2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P. 1969 Volkswagen Bug This is my first meeting, I have a horsepower problem. |
06-09-2009, 05:23 PM | #10 |
Yeah when you said wheelhop I immediately "knew" you had leaves, so when you said coils I then though they don't wheelhop, unless bushings are bad, check em out, poly bushings are great for the rears, they'll stiffen everything right up!
06-09-2009, 06:35 PM | #11 |
Thanks for all the advice. I will check my bushings, that makes alot of sense. I only drive this truck on the weekends because it is a tad bit to radicle to drive every day, i just want to keep the stock look and not use ladder bars or a narrowed sub-frame. Thanks again, Shawn
