06-09-2009, 06:14 PM | #1 |
Seat belt retractor covers
Can anyone tell me how to release and raise the plastic cover on the floor mounted retracting part of the seat belts to get at the mounting bolt? I need to remove and reinstall mine for floor work. My covers are in pretty good shape and don't want to damage them in the process.
06-09-2009, 06:52 PM | #2 |
member #16
Re: Seat belt retractor covers
They pull off. wiggle back and forth while pulling.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
06-10-2009, 08:17 AM | #3 |
John, thanks for the quick reply. I took them out last night and it was just as you said. I thought that they might have a tab or two that needed to be released but they were just pushed on over the mechanism.
Don |
06-10-2009, 08:19 AM | #4 |
Tot Roddin'
I know what you mean Don, those little things can be kind of tricky to get loose. I always worried about tearing them up.
Glad to hear they came off for you!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
06-10-2009, 11:45 PM | #5 |
The Older Generation
I always use a heat gun on mine to warm them up first. A hair dryer would probably work too. It makes removing and installing much easier... LockDoc
06-11-2009, 07:50 AM | #6 |
Tot Roddin'
Now that's a good idea Leon! I just have to make sure the wife isn't home...
06-11-2009, 09:52 AM | #7 | |
LockDoc
06-11-2009, 10:04 AM | #8 |
PROJECT 7DEUCE
Does anyone know how to make them fit tight when you put them back on? The ones in my blazer are pretty loose?
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
06-11-2009, 12:02 PM | #9 |
Mine were pretty tight and didn't seem to want to just pull off. That's why I started wondering if there were hidden clips or tabs. But they did just slide off when enough force was used. The heat trick is a good idea, especially in cold weather.
They seem to just squeeze on over the retractor hardware, so using something to stick inside the plastic cover where it makes contact should make them fit tighter. Something like adhesive backed felt or rubber? Don |
