Old 01-02-2003, 06:50 PM   #1
Dandeluxe
Dandeluxe's Avatar
Ways To Drop Slightly
A WHILE BACK I MADE THE DECISION TO INSTALL ALL NEW SUSP. PARTS. I WENT ALL ORIG. STOCK SUSP. MOST FROM EARLY CLASSIC. MY ? IS HOW CAN I LOWER IT WITH OUT CHANGING THE FRONT SPINDLES. IM LOOKING TO MAYBE DROP 2 OR 3 INCHES IN THE REAR AND FRONT. IM WANTING THE LEVEL LOOK. IM WONDERING IF I CAN CALL EARLY CLASSIC AND GO WITH 2 OR 3 INCH LOWER REAR SPRINGS AND MAYBE SOME 2 OR 3 INCH LOWER SPRINGS IN THE FRONT ALSO. OR IS THERE A BETTER WAY W/O CHANGING THE SPINDLES. NOTE: IT IS A DISC. BRAKE CONVERSION FROM EARLY CLASSIC WITH 6 LUG BLAZER RALLYS.
ANY SUGGESTIONS ARE GREATLY APPRECIATED.
THANKS, DAN
1969 cst swb 350/400 th . DANNY C .
["]FRIENDS DONT LET FRIENDS DRIVE F@RD$!!
1969 cst swb corvette hugger orange with 400 hp sbc
I started out with nothing and i held on to it
Dandeluxe is offline   Reply With Quote
Old 01-02-2003, 08:05 PM   #2
crazy longhorn
Fabricate till you "puke"
You could go with a 2" drop spring up front, but looking at your truck......I would say the back is approx 2 1/2 - 3" higher at the rear. if you want level, i would say you will need to go about 5" at the rear if you drop the front 2". I like em with a little rake, & would say a 2/4 would give better axle clearance at the rear, without notching the frame. You may be looking at an adjustable panhard bar & some shock relocators at the rear tho.....
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-02-2003, 09:00 PM   #3
progress
Gotta luv a clean shave
Inexpensive lowering springs for the rear, if you don't care about load carrying capacity, are GM "A" body springs. Find them in a junk yard or a swap meet. I got mine for $10 at a swap meet. Those should lower about 2" in the rear. I haven't installed mine yet so don't know how much they will lower it.
Welding while you wait...you can help if you like and it...might even save you a little as long as you don't mess things up!
We make house calls too...just like the old days!
progress is offline   Reply With Quote
Old 01-02-2003, 11:36 PM   #4
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
If you don't want to swap spindles. Then the most you want to go in front is 2" or you will never be able to align it. The rear about 4" to level it.
01 Tahoe 22's 2/4 drop and tv's
68 chevy money pit
51 chevy belair
95 Honda 900RR
05 GMC Siearra (company truck)
NSANE68!!! is offline   Reply With Quote
Old 01-08-2003, 08:28 PM   #5
Dandeluxe
Dandeluxe's Avatar
SPRING DROP
TTT
