steering shaft/rod
Does anyone know what size the rod/shaft is that runs through the steering wheel for a 65 chevy c10. Its the rod that you bolt the steering wheel down to. Its a stock steering wheel. Thanks
Grandpas truck, my dream. This is my truck. There are many trucks like it but this one is mine. 65 Chevy C10 Fleetside |
Re: steering shaft/rod
I am not sure what size the shaft is but i have use the shaft from a 71-77 in a 66 steering column.....just have to use the nut from the truck you took it out of....
the solid rod is 9/16ths I believe.....
thanks guys this info will help me out.
Watch out for your cornhole !
![]() Join Date: Jun 2003
I just walked out into the shop and measured the one in my truck with a digital caliper. It is .750 or 3/4 inch.
Hey thanks for that info. I am going to try to get a tap and die set this weekend so I can rethread the end that the nut goes on. I stripped mine but I think I can salvage it.
Hmmm. Mine seems to be 1/2 inch. I will have to see if I can rethread it.
#8 | |
![]() the 3/4" is the diameter of the shaft between the column and gearbox....I realize the threads for the steering wheel are on the same shaft, but that end is machined down to a smaller size...I would guess it is 1/2-13 thread..if it is stripped too bad there might not be enough material there to re-thread it...guess if you had to you could re-thread ti to a 12mm thread and get a new nut...
If you can try to use a thread gauge and measure the thread pitch.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD |
I found 1/2 x 20 die today at oreillys auto parts. Steering wheel is now nice and tight. Thanks for the help everyone.
