Old 06-11-2009, 04:58 PM   #1
1987_3/4ton_chevy
Cowboy Up
u bolts
I got some u bolts but they are to long. The threads don't go up high enough to tighten the plate to the axle. It wouldn't hurt anything if we use washers to fill that gap would it?
1971 chevy k10 *Under the Knife*
Chris Cary
1987_3/4ton_chevy is offline   Reply With Quote
Old 06-11-2009, 07:01 PM   #2
JimKshortstep4x4
Re: u bolts
How much space do you have to make up? If it is a small amount it would be ok, but I would suggest using hardened steel washers. If it is a lot I would suggest individual steel spacers for the space needed to fill.
Hardware grade washers stacked up tend to compress over time which could allow the rear end to move.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 06-11-2009, 10:07 PM   #3
big mike71
big mike71's Avatar
Re: u bolts
Buy the right size bolts they are cheap and if you rig it up you won't be happy.
big mike71 is offline   Reply With Quote
Old 06-11-2009, 10:09 PM   #4
BAGNDRAGIT
Just Not Low Enough!
BAGNDRAGIT's Avatar
Re: u bolts
Agreed, do it right the first time. you will thank yourself.
NEED ELECTRICAL HELP? ASK ME!
67-72 Full Wiring Diagrams
Lots Of Info, TAKE A LOOK
1967 Chevy C-10 Shortbox Bagged 327 4spd
Previous:
1971 Chevy C-10 Short Sep I6 Auto (Traded)
1973 Chevy C-20 *THE REDNECK BATTLE TRUCK*
2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P.
1969 Volkswagen Bug
This is my first meeting, I have a horsepower problem.
BAGNDRAGIT is offline   Reply With Quote
Old 07-03-2013, 09:44 PM   #5
Sacramento70
Blazer Fanatic
Sacramento70's Avatar
Re: u bolts
Not true a local spring shop quoted me $86 for 4 new u bolts that fit our blazers ... remember always go new because u bolts aren't designed for second use as they have thread that gets cut into by the bolt as you tighten them down ....just something to think about...by the way my 70 blazer rear end u bolts measure 5/8 by 2 5/8 by 7 1/2
1970 Chevy blazer
Sacramento70 is offline   Reply With Quote
Old 07-04-2013, 12:08 AM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: u bolts
I had a set of U-bolts made by my local spring shop... cost me about $20 bucks. That was for the U-bolts, nuts and hardened washers. So yes... true!
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 07-04-2013, 12:59 AM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: u bolts
Hmmm, a 4-year-old thread revived, interesting!
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 07-04-2013, 06:10 AM   #8
cdowns
cdowns's Avatar
Re: u bolts
in 4 years i wonder if anybody thought to just cut some more threads so they could tighten the ubolts??
Old 07-04-2013, 09:04 AM   #9
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: u bolts
^^LOL^^, I agree, I thought thats why people had tap and die sets?
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
