big block conversion ????????????
This question is how i found this site.I have an 88 blazer love the blazer but while i was otr driver the body roted from sitting.I bought a military 85 blazer with bad motor and basically a parts truck with a good body and frame interior already stripped out which is actually better for me being i want to use my interior and wiring harness from 88.The plan is lift body off and and basically build from frame up.well my little 350 while pushing decent ponies I was thinking of putting a big block in it.I can get a 91 454 SS pickup with about 140k for about 600 in spring.I was thinking i could leave tbi unit to help with fuel economy.What are some of the problems i might run into with the 454?? my dream would be to have a 427 or 396 but thinking i won't find one of them reasonable enough for me to afford.
Arrived on a Pale Horse
Re: big block conversion ????????????
Subscribing to this thread, sounds like a cool plan. As long as you keep the 88 harness with the tbi, ecu, sensors, etc transferred to the bbc you should be good. Someone will undoubtedly correct me if Im wrong tho.
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
huh ???
The 454 is only 20 more horses than the 350 stock for stock. The torque though 85 more lbft than the 350...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
baby jay thanx i was thinking same thing as keeping the wiring harness would work 72 i wasn't totally sure how much of a gain the bb would be.by the way here is a couple current pics of the 88
Well, get it in there already!
spring time is when i get the 454 that pic is my donor vehicle i'm taking everything from this to the military.Right now trying to learn and make sure everything will work as i think or find out if people have had problems doing similar project
Low & Fast!
Not to bad for a parts truck. Keep us posted on this one!
i've had this truck since my bro died in 96 sorta hard to stop this one but when all converted the the military 85 it will live again at least in my head
#9 | |
Low & Fast!
Sorry about that, but happy that you are doing something with it and just not letting it rot..
huh ???
230 hp @ 3600 rpm's 385 lbft torque @ 1600 rpm's...
Chuck
The 454 TBI flows 650 CFM.
There is a carburetor sizing formula out there, that is a rough guide to getting the right carb air flow CFM (cubic feet per min) but It works okay for TBI. CFM = (RPM times CID) / 3456 3600 X 454 / 3456 = 473 CFM Though the TBI is rated 650 CFM, the motor is likely running 75% volumetric efficiency with a restrictive intake cam and exaust... 650/0.75 = 487.5 Which explains why the power peaks at 3600, because that's where the airflow peaks. This low end power is excellent for tow/hauling. The rest of the motor (camshaft and heads,) is designed to accomidate this, so if you use a bigger TBI, not much will happen. Until you get into cams and heads. Plus the more modifications you do, the more you need to do custom chip tuning. Basically I'd find a cheaper 454, or cheaper small block.
79 Blazer Cheyenne, 2wd 305 3.42 stock 85 Caprice, TBI converted, new 350 crate motor, Monte Carlo SS Wheels, Bilstein shocks, |
thank you guys for the technical info.Now i'm wondering wether to find an older big block or just put money in my motor/I like the ideal of the torque of the bb
sb to bb its crazy were the power is i have had couple built sb but the truck i have now has a off road 502 in it the 450 hp one and its so fun
1981 K-5 Blazer 2wd 1985 C-10 Short step 1988 C-10 Suburban ![]() |
