Old 06-13-2009, 02:32 AM   #1
Ray Rust
Ray Rust's Avatar
Thumbs up Bag install for 69 front
Hi Guys just fitted up bags as coil replacements on rear , ride height is a lot better , any help or advice ( pictures) on fitting front bags thanks in advance Ray
Ray Rust is offline   Reply With Quote
Old 06-13-2009, 09:56 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Bag install for 69 front
Nice truck!
I suggest you search around in the suspension section. There are quite a few members on here that are running bags.
Keith
Convert to disc brakes.
Old 06-13-2009, 11:53 PM   #3
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Ray, what drop did the '69 have before the rear bags?
Search through several of the threads in the suspension section as lolife99 mentioned and you will be set. Even in some of the build pages (sub forum under the 67-72 Message Board) will have several install threads for you to read through as well.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 06-18-2009, 02:28 AM   #4
Ray Rust
Ray Rust's Avatar
72BlackBeauty I think it was 4" all around , but that didn't give me the result I wanted , so I went the bag option which tucks the tyre nicely now for the front ...here's a pic before the bags
Cheers Ray
Old 06-14-2009, 09:48 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Are you keeping the drums up front? I suggest you upgrade to a later front suspension that includes disc brakes.
As far as adding bags, it's pretty simple. You remove the coils and ad mounting plates up top. You can use cups on bottom, or explore other options if you want to get lower.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-18-2009, 02:21 AM   #6
Ray Rust
Ray Rust's Avatar
Thanks N2Trux running drums and gonna stay that way at the moment
cheers Ray
Old 06-15-2009, 04:49 AM   #7
blime81
Laid Lo
blime81's Avatar
N2TRUX-
Are those plates from *****************? Looks like a good fit. Did you just use drop shocks or are you running different brackets too? Thanks
Semper Fi,
Jeff
'72 C10 - lays frame
'07 Sand Rail - ecotec powered
'05 2500HD - tows stuff
'67 VW Bug - gas saver
'01 Jeep TJ - rock crawler
blime81 is offline   Reply With Quote
Old 06-18-2009, 09:15 AM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by blime81 View Post
N2TRUX-
Everything on my truck is from Air Ride Technologies. The shocks are shorter heavy duty fluid shocks with stock brackets.
Articles-
"Refining Sierra"
Old 06-18-2009, 02:40 PM   #9
bmfpeterson
bmfpeterson's Avatar
good lookin truck!! the rear looks a lot better....
bmfpeterson is offline   Reply With Quote
Old 06-18-2009, 03:35 PM   #10
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
I just went though this and the best way is to cup the lower A arms 2 3/4" works perfect and gives a great ride and stance...
spraybomb has a great post on how to do it but it's basicly a 8"X23/4" piece of pipe a piece of flat stock and you cut out the lower spring pocket and weld in the pipe....
and the monroe 5257 works great for the drop
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 06-18-2009, 03:34 PM   #11
XXL
Señor Member
XXL's Avatar
N2TRUX-
Those look like ART brackets.
edit: oops... should have read further in the post. What N2TRUX said.
XXL is offline   Reply With Quote
