06-15-2009, 09:23 PM | #1 |
3/4 ton cab v.s 1/2 ton cab??
is there a difference between a 3/4 ton cab and a 1/2 ton cab, like the way they mount to the frame?
1965 c/10 swb 1969 c/10 lwb |
06-15-2009, 09:30 PM | #2 |
Watch out for your cornhole !
Re: 3/4 ton cab v.s 1/2 ton cab??
No differences in the cab itself. The frame mounts and rubber cab mounts are different though.
06-15-2009, 09:52 PM | #3 |
its all about the +6 inches
only thing is the 2 on the VIN instead of a 1.
06-15-2009, 10:53 PM | #4 |
Junior Member
A little off thread but:
My son and I found out the hard way that the cab mounts are different on a 3/4 ton than on a 1/2ton. We took a cab off a 3/4 ton and put it on a 1/2 ton frame using the 3/4 ton cab mount stuff. When we tried to align the front clip we found the gap at the fender to the cab would not work. One day when I was searching this forum I found out why. The frame brackets on 3/4 ton and 4X4s are lower on the frame allowing for thicker rubber mounts to allow for a smoother cab ride. Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
06-15-2009, 11:05 PM | #5 |
this makes me wonder. I bought a cab and was "told" it was from a 1/2 ton. How do I really know?
06-15-2009, 11:32 PM | #6 |
the vin?
06-16-2009, 10:04 AM | #7 |
06-16-2009, 02:30 AM | #8 |
Andy, such a short answer,
Help another one out. You know he's new
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
06-16-2009, 10:21 AM | #9 |
...just another truck junkie..
If you have no VIN plate or any numbers to go on, then there is no way to tell and it really won't matter. The actual mounts on a 3/4 ton are different. The cabs are totally identical, the mounting locations are the same.
Mike "Bear" Shea |
06-16-2009, 10:52 AM | #10 |
06-16-2009, 06:07 PM | #11 |
i figured I'd be a smart ass, since keven already answered the exact same question, on this thread, in the first responce.
i'm just sayin. |
06-16-2009, 09:52 PM | #12 |
Moderator
Good question, and good answers. I was wondering if I could just buy a set of cab mounts for a 1/2 ton for my 3/4 ton truck....since the 3/4 ton mounts cost twice as much. Now I know that I cannot do that and will have to buy the 3/4 ton ones
06-17-2009, 02:38 AM | #13 |
so baisically if you have a 3/4 ton cab, then you use the 3/4 cab mounts if you were to put it on a 1/2 ton frame?
06-17-2009, 02:41 AM | #14 |
Gone to greener pastures
I think you may have it backward.
Use the mounts that go with the frame.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
06-17-2009, 07:11 AM | #15 |
You are overcomplicating this. El Jay has it right, you just use the mounts that are on the frame. The cab doesn't care if the chassis is 1/2 or 3/4 ton, it will sit there, bolt up, and look pretty either way. In a nutshell, don't mess with the mounts, just slap the cab on.
Mike "Bear" Shea |
06-17-2009, 12:22 PM | #16 | |
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
06-17-2009, 03:25 PM | #17 |
Neither the 3/4 or 1/2 would work on my truck so we had to come up with a custom setup. We ended up with a 2" body lift.
Save your money and do it right the first time. 1968 GMC short bed 1972 Cab 74 SB Chevy running gear |
06-17-2009, 03:31 PM | #18 |
Slight tangent on the same thread:
My cab mounts are there, but severely cracked and dried out. I'll also add that I have a very BOUNCY 1-Ton. Will I actually notice a ride difference if I replace the mounts? Or will it just be money down the tubes? |
06-17-2009, 04:44 PM | #19 | |
Yes, you will notice a ride difference. Replacing those dried out cushions with some new ones will provide a lot more give than the current ones do.
Mike "Bear" Shea |
