Old 06-15-2009, 10:31 PM   #1
kev93
12 bolt or 9"ford?
I have a 77 shortbox 2wd with stock 12 bolt rearend. I have heard these rear ends are weaker than 12 bolt car rear ends. I am building a hi po smallblock for it. Around 425hp. Will it take abuse from burnouts to hard launches? Is there any Ford 9" rear ends that will bolt in? thanks
kev93 is offline   Reply With Quote
Old 06-15-2009, 11:11 PM   #2
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: 12 bolt or 9"ford?
I would add some c-clip eliminators if you are really worried about it, but it should hold up just fine.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 06-16-2009, 02:52 AM   #3
Pyrotechnic
Pyrotechnic's Avatar
For that power level it will be fine. It's weaknesses are the smaller pinion shaft and the stock carrier. The pinion shaft is smaller than a car 12 but it should hold fine. Put a good posi unit in it to eliminate the stock open carrier and it will be pretty strong.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 06-16-2009, 09:53 AM   #4
454HO
Someone posted in the racing forum a couple weeks ago that there is a special pinion bearing available that lets you run a car ring & pinion set in a truck housing. I never saw him post the part number though. Here is the thread -
http://67-72chevytrucks.com/vboard/s...d.php?t=346472
- Greg
454HO is offline   Reply With Quote
Old 06-16-2009, 11:00 AM   #5
Pyrotechnic
Very interesting. I thought it couldn't be done but it looks like it very well can. Has anyone actually ever had issues with the pinion shaft on the truck 12 breaking under hard use ?
Old 06-16-2009, 01:11 PM   #6
kev93
The size of one bearing is the only difference? Would you still use the the truck posi unit and gears???
