Old 06-16-2009, 12:12 AM   #1
Thadious
Derusting...
Anyone have any recommendations on the best way to remove/neutralize rust on the inside of a door so it can be coated?
Ted.
'51 Chevy Build - In the design stages
Aut viam inveniam aut faciam - I will either find a way or make one.
If you don't have time to do it right the first time, when will you...
My new build - https://67-72chevytrucks.com/vboard/...70#post8958970
Thadious is offline   Reply With Quote
Old 06-16-2009, 12:19 AM   #2
ezekiel
Re: Derusting...
Some people use POR15 so that they don't have to completely remove the rust.
Apparently, all you have to do is brush off the flaky rust with a wire brush and then apply POR15 overtop of it.
Take a gander at this page to read the instructions.
Is this the kind of info you're looking for?
Zeke
ezekiel is offline   Reply With Quote
Old 06-16-2009, 01:11 AM   #3
sighlurr
______________
sighlurr's Avatar
Re: Derusting...
I always liked this stuff, but don't have any experience with it yet:
http://www.missbelvedere.com/missbelvedere.asp
sighlurr is offline   Reply With Quote
Old 06-16-2009, 01:37 AM   #4
OrrieG
OrrieG's Avatar
Re: Derusting...
With por15 you first apply a rust converter then metal prep then the por15. So far it has stuck to the parts I finished two years ago, but the truck has been in the garage, never seen weather. If you don't use the rust converter it will still be there. I suspect that over time it will come back or continue because "Rust Never Sleeps". All I want to buy is 20 years or so then my grand or great grand kid can deal with it! I figure it can't get any worse than the previous 50 years.
Old 06-16-2009, 02:00 AM   #5
Thadious
Re: Derusting...
On a vast majority of the small stuff, I've been using the Electrocatalytic rust removal process with excellent results...
I'm just wondering if there was an easy way to deal with the stuff inside the doors before I coated them...
I understand that POR15 will adhere quite well to solid, non flakey rust, as I've been using it's counterpart here (Zerorust) for quite some time with great results.
Thanks again,
Ted.
Old 06-16-2009, 01:46 PM   #6
Fred T
Cantankerous Geezer
Fred T's Avatar
Re: Derusting...
That's not quite right. The POR-15 system consists of Marine-Clean (a degreaser), Metal-Ready (a metal etch similar to zinc phosphate) and their POR coating.
POR was a top of the line product some 20 years ago, but there are now others that are just as good, cost less for the system, and are easier to apply. Eastwood, Rust Bullet and ZeroRust are some. They also come in rattle cans, which POR can't use due to the chemicals in their product.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 06-17-2009, 08:33 PM   #7
texacokie
texacokie's Avatar
Re: Derusting...
I guess you could use the miss belvedere stuff and get it off then coat it with rust bullet....sounds like a plan to me.
texacokie is offline   Reply With Quote
Old 06-17-2009, 08:48 PM   #8
Thadious
Re: Derusting...
That may be the way I'll go... little bit of spray setup with shower curtain and a kid's plastic pool...
Hopefully I can get it into Canada....
Old 06-17-2009, 07:09 PM   #9
texacokie
texacokie's Avatar
Re: Derusting...
wow that stuff is incredible...got to get some of that, save many hours of work
