Gear Shift Removal
I wanna take the gear shift out of my '70 and shorten it. Its a 4 speed manual on the floor. The service manual says something about a tool and makes no mention of what looks like a pin going through the side. Do I need this tool?
Matt 1970 C10 |
Loving the Jimmster
Re: Gear Shift Removal
I have done this twice the last month, the first one i ruined. if you push down on the rounded part, (the shifter comes thru), it will go down just a little and allow you to turn it a quarter turn, then it will lift right out.
You do not need a special tool. Take a pair of Channel lock pliers, press down on the coller & turn it ccounter clockwise about 30 degrees. It should lift right out.
Turn the collar or the shifter counter clock wise? I assume the installation is just in reverse?
Matt 1970 C10 |
Place the shifter in neutral and turn counter clock wise on the bulb that is around the shifter no need to mess with the pin. Should not even need pliars if you use a little wd-40 of similar first.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
![]() Join Date: Sep 2007
i could have learned this last week I just unbolted the whole plate on mine >
1967custom |
Ok...getting it off was easy...no tools required. But do you have any tips for putting it back on? that spring is one stiff sucker and I cant push it down far enough by hand.
Matt 1970 C10 |
Actually im starting to suspect the gearshift is not seated far enough into the tranny. When I look down into the opening, I dont see a clear slot for the shifter to seat into. Right in the way is a spring loaded stainless pin on its side. Is this right?
Matt 1970 C10 |
Ahhh never mind. I got it. The little pin (that I assume is for the reverse gear) was in the way. I pushed it back with a screwdriver and all is good.
Matt 1970 C10 |
