06-19-2009, 05:40 PM | #1 |
Close up pics of front and back window trim
Am I correct that the front and rear windshield on our trucks had both a plain back rubber trim as well as a chrome trim that went around the window and windshield?
If so do they all work on all years? anyone have pics of the differences? Trying to decide which way I may want to go with it. |
06-22-2009, 02:47 PM | #2 |
Re: Close up pics of front and back window trim
ANyone? no one?
06-22-2009, 03:07 PM | #3 |
TOTY 2006
There is standard window rubber that has no trim that was available 67 to 72.
There are also two kinds of chrome trim (with correct Delux gaskets) for the front window and back (large) window. Earlier chrome has deeper back sides, (67-68) while the later trim is shallower on the back side. So the tricky part is to make sure you have the correct gasket for the trim you have. Once you have correct gasket for the trim, yes, you can use either trim for any of the 67-72 truck (minus 67 small back window as back trim for the 67 small window was not an option.) That help? Last edited by John Fabris; 06-22-2009 at 03:09 PM. |
06-22-2009, 03:19 PM | #4 | |
any cab can take any trim once you buy the right gasket right? cause Ill be purchasing my window and trim together |
06-22-2009, 07:23 PM | #5 |
I don't know if this is what you want, but here it is.
06-22-2009, 07:41 PM | #6 |
06-24-2009, 01:34 PM | #7 |
Anyone else?
06-24-2009, 01:44 PM | #8 |
Yes, that's the stainless trim which fits into a channel on the custom rubber window seal. The standard black seal does not have a channel to accept the stainless trim.
any help? |
06-24-2009, 02:03 PM | #9 |
motor exploder
trim pic is the first one, rubber only is the 2nd...
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
06-24-2009, 02:19 PM | #10 |
