Old 06-19-2009, 09:46 PM   #1
liv2ryde
please help; post up your pic's and spec's
I have a 79 C10 and would like ideas on what direction to go with it. I am thinking about a 3/5 drop and I am not sure how I want to do it plus I am looking for ideas on wheels and tires. Does anyone know the largest 15" tires that can be had and fit? I have a set of 15x10 rear and 15x8 front's needing bigger rubber (currently wearing 275/60 rear and 215/70 front and they look tiny in the 1st pic's. The 20's in the next picture's, I decided I don't care for, besides they won't work to tuck under a drop of any kind. Thanks in advance for your pictures and specifications!
liv2ryde is offline   Reply With Quote
Old 06-19-2009, 11:26 PM   #2
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: please help; post up your pic's and spec's
that set up you have now with 15s would look good with a 5/5 drop, and your trany and brakes will thank you once go back to 15s a bet those 20s are heavy
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 06-20-2009, 09:52 AM   #3
CoggedBelt75
CoggedBelt75's Avatar
Nice truck liv2ryde! Will look even better if and when you decide to drop her downsome. Here is what I can offer........
'75 c10
7/7 drop
non back halved c-notched frame
narrowed 12 bolt 44" flange to flange
4-link panhard bar koni coilovers
mini spool
4.56 richmond gears
C-clip eliminator
moser 30 spline axles
wilwood disc brake kit
back wheels - Convo-Pro 15x14 4 1/2" backspace
back tires - Hoosier Pro-Street radials 31x18.5R15L tread width: 14.5
room to spare to run set up for slicks
cragar soft 8 wheels (for burnouts) 15x14 4 1/2" backspace
Hoosier Drag 32.0/14.0/-15 tread width: 16.3
CoggedBelt75 is offline   Reply With Quote
Old 06-21-2009, 04:56 PM   #4
liv2ryde
Thank you, and yes the 20's are heavy and they are gone, back to the 15's for now. Thanks Cogged! Great info!
Old 06-21-2009, 07:09 PM   #5
Keith Seymore
Keith Seymore's Avatar
I recommend that you check out this thread:
http://www.67-72chevytrucks.com/vboa...d.php?t=323014
It is two pages long, and the guys included the amount of drop, techinique used, tire sizes and wheel sizes and backspacing.
You might get some good ideas based on that.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 06-22-2009, 09:46 AM   #6
jwa76fleetside
jwa76fleetside's Avatar
i like it how it is...?
76 Chevy Fleetside
63 Lincoln Continental w/ Ford Racing 460 (550hp)
2012 VW GTI
2013 Escalade
2008 Harley
jwa76fleetside is offline   Reply With Quote
Old 06-22-2009, 04:48 PM   #7
TwinTurbo
TwinTurbo's Avatar
I have 275s on the rear w/ 1.5" spacers 10X15 wheels. I could fit a lot wider wheels/tires in there but can't find a neat set of 5on5 rims and some nice wide 15" tires.
Rolled out fenders, drop spindles, flip it, shackles..blablabla....
TwinTurbo is offline   Reply With Quote
Old 06-22-2009, 10:59 PM   #8
Tony_SS
Tony_SS's Avatar
I like the big 20's!!
Why not go back to your 09 '18's? I took that idea and ran with it.
Tony_SS is offline   Reply With Quote
