Old 06-20-2009, 10:37 PM   #1
CPNE
Resident Curmudgeon
CPNE's Avatar
402BB PS Pressure hose help
I need the PS pressure hose for a 72 2wd 402 BB truck. Anybody have a part # I can give NAPA to cross reference or a source for this? A couple of years ago I got one no problem, now it seems not to exist.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 06-20-2009, 11:25 PM   #2
71 super
71 super's Avatar
Re: 402BB PS Pressure hose help
If looking for a direct stock appearing replacement to my knowledge there is not one in the correct configuration (long metal tube that follows the frame) you may try advance or some other if not want "correct"- if you want the right hose Pickemup is the only one that has the correct piece reproduced.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 06-20-2009, 11:30 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
while not anwering the question, i CAN say the one from LMC is lame. Real thin metal, needing a lot of tweaking, and I doubt it'll last long. (72 402)
Old 06-21-2009, 08:05 AM   #4
RustyParts
RustyParts's Avatar
A local Industrial hydraulic shop can build one for you. They would need the old one for a reference.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires
The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers!
RustyParts is offline   Reply With Quote
Old 06-22-2009, 07:36 PM   #5
425HP409
425hp409
425HP409's Avatar
Napa has two hoses listed for the 72 BB. NPS 71634 and NPS 71531. I don't know which one is correct as they both show the same ends in one description but show one has a male and one a female pressure port. I would get both to see which one would work for your truck.
Charles
68 SWB, Dad bought new, now 396 & factory ac
64 Impala SS, 409 425HP, 4 speed AC
64 Bel Air Wagon, 400 Small Block
57 Bel Air all original 283 w/Factory Air
77 GMC Sprint, 454/425HP
67 Olds 442, all original
90 ZR1 Corvette
425HP409 is offline   Reply With Quote
Old 06-22-2009, 08:24 PM   #6
tim21391
tim21391's Avatar
i never could find one that i liked so like they said couple post before.. i took my old line to a hydralic shop and they just put on a new rubber part.. used the same hard line.. cost $33 but then i knew it wasnt no junk
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 06-22-2009, 08:43 PM   #7
leddzepp
Moderator
leddzepp's Avatar
The ones that Napa and other parts stores have are incorrect. A hose shop is the way to go to have one made up.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 06-24-2009, 02:18 AM   #8
BIGJAKE97
BIGJAKE97's Avatar
i got stainless steel one from frank (pickupman.) http://67-72chevytrucks.com/vboard/s...d.php?t=311917
-jake
67 short fleet
71 blazer 4x4
72 blazer 2wd
76 gmc sierra 3/4t 4x4
62 bel air
01 blazer extreme
member 11,943!
BIGJAKE97 is offline   Reply With Quote
