06-21-2009, 06:50 PM | #1 |
Shift Needle indicator
I am missing the shift indicator needle are they easy to find? (i.e order new) or are they junkyard only parts?
Adam M STX Designs Motorcycles | Choppers | Hotrods |
06-21-2009, 07:04 PM | #2 |
Plays with trucks
Re: Shift Needle indicator
Depends on if you have a TH-350 or 700-R4. TH-350's are plentiful, 700-R4 not so much. Heck, I even have a spare 350 indicator I could part with for not much more than shipping.
Gary My Dad's Old Truck 1985 |
06-21-2009, 07:06 PM | #3 |
I've got a 700r4, but wow I didn't know it made a difference for an indicator on the gauge cluster
Adam M STX Designs Motorcycles | Choppers | Hotrods Last edited by ShowSS12; 06-21-2009 at 07:06 PM. |
06-21-2009, 07:18 PM | #4 |
Plays with trucks
Not for the needle itself, the whole assembly. Sorry, I mis-read your post. You should be able to replace the spring/cable/needle assy with any other one.
06-21-2009, 07:32 PM | #5 |
You should be able to find the needle at any junkyard. The cable was still available from GM, not sure if it still is. Was about $15.00 if I recall correctly. I would not screw with a junkyard cable, just buy a new one if you need it.
06-21-2009, 11:58 PM | #6 |
Thanks I have everything but I am just missing the needle that points to what gear your in...
06-22-2009, 12:09 AM | #7 |
6.0 powered square
I would get the needle at the junk yard because I think if you get it new its the entire assembly, which reminds me i need to find a needle for my truck because it's been without a indicator almost as long as I've owned my truck
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 06-22-2009 at 12:13 AM. |
06-22-2009, 10:53 PM | #8 |
huh ???
You can buy just the needle from Classic Parts. Part # 91-471 $11.95...
http://www.classicparts.com/1973-91-...info/91%2D471/ Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
