06-21-2009, 10:08 PM | #1 |
difference in bb and sb
My truck originally had a small block in it and i am planning on putting in a 402 bb. What is the difference in the power steering? Mine has the original sb power steering stuff?
06-21-2009, 10:16 PM | #2 |
My Carbon Footprint
Re: difference in bb and sb
what year is your truck? '68's and older where driver's side alternators and 69 up were pass side. When I put my 460 in my '68, I used this time to convert to long water pump and alt on the pass side. Made it easier to add power steering. Not sure if SBC and BBC used the same pumps or not.....but you will at least need BBC brackets.
06-21-2009, 10:25 PM | #3 |
Its a 72 frame with a 68 body
06-21-2009, 10:30 PM | #4 |
My Carbon Footprint
where is your alt? It's cool because you can still get the brackets through Chevy. I got the mid 70's style pump and it was a breeze.
06-21-2009, 10:35 PM | #5 |
Im not sure. Aint looked at in a while. Its a bone stock 402 out of 71 gmc 3/4. I thought the power steering pump was mounted on to the frame? Hows it work?
06-21-2009, 10:39 PM | #6 |
My Carbon Footprint
No...it's mounted to the motor. The gearbox is what's mounted to the frame.....hang on....baby crying....
06-21-2009, 10:53 PM | #7 |
Truck pump should have a remote reservoir up on the driver side fender if stock, but any B.B. power steering pump will work. The brackets are different from sb to bb
06-21-2009, 11:12 PM | #8 |
Roadtrip!
Originally through 72 the alt. is on the drivers side. Hart rods pic shows a correct set-up. The long water pumps came later for the trucks i believe.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
06-21-2009, 10:51 PM | #9 |
My Carbon Footprint
If it's out of a 71 it should be a long water pump and a pass side alt. Easy to put on pump (not saying the other was is not easy....this is all I know). The only thing that I can't answer and someone else will is if the small and big blocks used the same pump. I picked mine up for $20 so either way it will be an easy conversion. I paid under $50 for both my brackets brand new. Gearbox is the same either way.
06-21-2009, 10:53 PM | #10 |
Here's some photos of my bone stock 71 402:
R/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
06-21-2009, 11:23 PM | #11 |
its all about the +6 inches
all V8 engines in 67 - 72 trucks had the shrot pump.
All small blocks always had the alt on the drivers side, and power steering mounted below it. All big blocks were the same. None of the brackets interchainge small block to big block |
06-21-2009, 11:33 PM | #12 |
LHM to the rescue again... Thanks for clarifying... For a moment I thought my whole engine was a** backwards!
06-22-2009, 12:07 AM | #13 |
My Carbon Footprint
Holy cow! I was assuming that GM made the switch to the cars and trucks. I'm a Camaro guy 1st, formost and always. Sorry to steer you wrong. The info I gave you was for cars. I'd take that remote crap and throw it as far as you can. Looks like a$$. Actually, I sold mine on ebay for a ton of money and went with the pump and res in one. Much easier and cleaner. Once again...sorry to confuse. I have to run upstairs now and tell my wife I was wrong for once in my life......she will be pleased!!!!!! lol
06-22-2009, 05:29 AM | #14 |
LOL!
There are a few things on the trucks that were not done the same as cars. And, whith the exception of the corvette, you are absolutly right. The remote power steering is a good set up becouse it is very difficult for the 'average joe' to fill it up/top it off. The average joe wouoldn't have a real long/small funnel like most of us do, so it would be quite difficult to fill without making a mess or over filling. |
