Old 01-04-2003, 01:57 AM   #1
TERRYP
GYRO GEARLOOSE
TERRYP's Avatar
Quick question on 3/4 ton rear install.
On my '68 C-20, I aminstalling the 'pumpkin' on an Eaton-Type axle. Does that side of the differential get a gasket? I cannot tell from the looks of the old surfaces.
Thanks...
Nevada City, CA
Everett, Washington
57 3/4 rat, 235, 3spd
66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring
68 C10 LWB 350 4spd, 4.56 rear dump runner
82 Camaro, 305, THM-200-R4
84 Monte Carlo 305 TH350, land tuna
85 Tercel SW, snow runner
DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB
TERRYP is offline   Reply With Quote
Old 01-04-2003, 03:43 AM   #2
jostrans68
Jostrans68
jostrans68's Avatar
It had one on mine I just put mine back in and I used silicone it will set a few months anyways so should be ok.. I have never used gaskets on either side of any of my others..My .02 Jack
[CGTW Member
former 67-72 now with a 96 silverado
jostrans68 is offline   Reply With Quote
Old 01-04-2003, 04:19 AM   #3
TERRYP
GYRO GEARLOOSE
TERRYP's Avatar
thanks, think I'll use ultra black, and use the gasket I bought on the backside, might as well use it.
Nevada City, CA
Everett, Washington
Old 01-04-2003, 05:25 AM   #4
COBALT
COBALT's Avatar
Silicone II Window & Door sealant from Home Depot (blue, black and gold cauk tube). I use it on my differential and when I install intake gaskets. Zero leaks.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 01-05-2003, 12:04 AM   #5
Duallie
Duallie's Avatar
There is supposed to be a thin paper gasket in front and a thicker gasket in back. Same bolt pattern front and rear, too.
Just as if I knew what I was doin'
Duallie is offline   Reply With Quote
