Old 06-22-2009, 11:05 PM   #1
Tony_SS
Tony_SS's Avatar
Rattling Brake Calipers Up Front
So my calipers are rattling. When I apply the brakes, they stop. I took the wheel off and it looks like the studs that hold them on are too small.. it rattles on them. OR could it be that I'm missing some grommets or bushings? Anyone know?
Tony_SS is offline   Reply With Quote
Old 06-23-2009, 07:45 PM   #2
SCOTI
SCOTI's Avatar
Re: Rattling Brake Calipers Up Front
The calipers have flat 'o-ring' style seals that should seat around the 2 caliper mounting bolts.
Another common issue is the pads themselves 'shifting' within the caliper when the brakes are compressed. This typically requires bending the tabs on the pads in a little tighter so there's an interference fit when installing them in the calipers.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 06-23-2009, 08:36 PM   #3
Tony_SS
Tony_SS's Avatar
Thank you!
Now any idea where I would find the o-ring style seals? Would this be an auto part store item hopefully?
I'll try the tab adj too when they go back on.
Old 06-23-2009, 08:43 PM   #4
silvereagle07
silvereagle07's Avatar
You can find the caliper seals(bushings) at Carquest in caliper rebuild kits. I'm sure you can find it other part stores too. Like Scoti said check the pads for the rattle and tighten the tabs near the hat of the rotor.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 06-26-2009, 06:51 AM   #5
Tony_SS
Tony_SS's Avatar
You all were right.. O'Reillys make a rebuild kit but I think I'm going to replace the whole caliper since they are only $11 each!
Old 06-26-2009, 01:09 PM   #6
joe231
joe231's Avatar
you don't need a rebuild kit....most parts stores sell the hardware kits....
here is the hardware kit from Autozone.
$4.99 for both front calipers
autozone linky
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 06-26-2009, 02:08 PM   #7
kelsfine69
18 Till I Die
kelsfine69's Avatar
I think your old GM caliper would be better than a new $11 one?
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 06-26-2009, 05:26 PM   #8
Tony_SS
Tony_SS's Avatar
You are probably right. But the caliber bolts have wobbled the mounting holes holes hence they rattle like crazy. Whoever put these on didnt use sleeves/grommets. I guess I can try the $5 kit first to see how bad the holes are first?
The $11 caliper come assembled with the bolts and everything.. I can't believe that cost, but I have always gotten good parts from O'Reillys so I trust that they are decent at least.
Old 06-26-2009, 07:16 PM   #9
LONGHAIR
If they will indeed tighten up the calipers in your situation, the rebuild kits are a much quicker/easier solution. Swapping the entire caliper will require bleeding....not you, the fluid.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
