Old 06-23-2009, 10:21 PM   #1
awhite4557
awhite4557's Avatar
Smile New LED headlights
Custom Classic Trucks had a new item in the Market Place of the magazine.... LED headlights. They are DOT approved, heres the link http://www.truck-lite.com/webapp/wcs...0001&langId=-1
1950 Chevy 3100 Ramp Bed 1-ton
http://67-72chevytrucks.com/vboard/s...d.php?t=749386
1965 Chevy Step Side
1971 Chevy Short Wide Bed
http://67-72chevytrucks.com/vboard/s...d.php?t=277191
1971 Chevy C-30 1-ton
1971 Chevy Chevelle
1972 Chevrolet C-30 1 ton
2005 Dodge Ram 2500 5.9 Cummins
2017 Fleetwood Pace Arrow 35M motorhome 350 Cummins
2020 Jeep Wrangler Unlimited Rubicon
awhite4557 is offline   Reply With Quote
Old 06-23-2009, 10:33 PM   #2
bigguy69
dazed and confused
bigguy69's Avatar
Re: New LED headlights
how much are they? they look neat.
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 06-23-2009, 10:37 PM   #3
Naterman35
good question... anyone know?
Naterman35 is offline   Reply With Quote
Old 06-23-2009, 10:52 PM   #4
purewhitemp5
I want to see them installed...need some pics of beam pattern on the road at night.
purewhitemp5 is offline   Reply With Quote
Old 06-23-2009, 11:18 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
very cool, and a very good idea, however, those in the rust belt need to know, in the winter, you'll have to wipe them off all the time when driving in the snow. They won't make enouh heat to melt the snow that lands on them, nor the sslushy spray from the cars in front of you.
Otherwise... an outstanding idea, and that is the company to expect a quality LED product, they have been making lights for big trucks for years.
Old 06-24-2009, 12:14 PM   #6
mrein3
mrein3's Avatar
Good point. Unintended cosequences. The good people of MNDoT and various cities and counties up here (Minnesota) read the reports on how long LEDs last verses regular lights in their stoplights. So they started changing them all out for LEDs to save money. Then winter rolled around and nobody can see any stop lights because the blowing snow that gets caught up there no longer melts.
He!! when I'm driving out to the fish house in the winter when it is twenty below or so even my sealed beams start to get snow/ice stuck to them. Not that I ever end up screwing around out there, spinning around, busting through snowdrifts and exploding powder all over my rig.
Another thing - and the reason why I don't run anything but standard sealed beam halogens - though the trick LED lights may never in the life of the vehicle burn out, a rock will take them out like any other headlight. If a rock takes out your sealed beam headlight you are as close as ANY auto parts store or Wal*Mart away from getting a replacement. If you bust a trick LED that you bought from "Bob's Fly By Night Ebay Store" you can't probably buy just one and if you can it probably won't match. Then you're screwed and you have to buy another pair for $300-$500.
Save your money. Keep your sealed beams and upgrade your headlight wiring to use relays, then use that $500 for a new set of heads or something that is useful to a truck.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 06-24-2009, 05:03 PM   #7
Werewolf
Woof?
Werewolf's Avatar
At least the people on that website had the sense to make the headlight polycarbonate, rather than glass. That's the stuff most glasses are made of, these days. It'd take a lot more to break them.
All your other points are accurate. And, I found out the hard way to never buy any first generation LED product, especially if it's High Output.
They usually have overheating problems, and heat is an LED's worst enemy. They will burn out, just not all at once. Worse, they might flicker and flash for a while instead of actually just dying.
I'd want to see these in use for a few years, and go through some updates before buying. Plus, by that time, they'll be a lot cheaper, too! These bulbs seem to have a warranty. That's a plus that I'd like to put into use on my job - 90% nighttime driving. I go through a set of headlights every few months.
LEDs are the light of the future, though. Incandescent bulbs will be going away in time. Perhaps not first in vehicle applications, but street and home lights will all go LED. I can almost see manufacturers that choose to use LED headlights also putting some kind of heater circuit in the 'glass' of the lens, like rear defrost for your headlights.
One thing that's always confused me in some advertisements about vehicle LEDs is the "power savings." They take less power. So what? The alternator may last a little longer (probably not) and it means you can use lower gauge wire to run your lights. Other than that, it's not like you'll see any significant MPG increase by removing headlight "drag" from the alternator... Although, in these trucks, yeah. LEDs would be a great way to get modern light from old wiring.
1968 LWB CST BB
2004 Avalanche Z71 LT3.
2003 S-10 ZR2 (hers).
1997 Astro
1992 Caprice wagon, 500k stock miles. Nursing wounds after a bad wreck.
1997 Saturn - need gas mileage from something!
Werewolf is offline   Reply With Quote
Old 06-24-2009, 12:22 AM   #8
1969InSeattle
https://www.ledheadlamps.com/tsMall/...PartNumber=679
This page shows them being back-ordered (not produced or shipped most likely) until 9/1/09.
I hope the $348 price tag is for the pair!
1969InSeattle is offline   Reply With Quote
Old 06-24-2009, 12:28 AM   #9
MonteSS454
MonteSS454's Avatar
I'll stick with my halos unless you can see like miles ahead of yourself with these.
MonteSS454 is offline   Reply With Quote
Old 06-24-2009, 12:52 AM   #10
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
are they just for chevys or do they have them for us 4 eyed guys?
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 06-24-2009, 01:41 AM   #11
Bugsy_malonn
Bugsy_malonn's Avatar
here are some $500
http://cgi.ebay.com/ebaymotors/Jeep-...Q5fAccessories
71 GMC 1 ton dually tow truck "Cooters tow truck from the Dukes of Hazzard"
1988 chevy 1 ton 4x4
Chevy step van "dont know what to do with it yet LOL"
1940 chrysler
1949 dodge panel rat rod
1989 jeep cherokee
"With a 8 inch lift and a ton of other stuff and two parts jeeps"
Then the wifes van LOL
Bugsy_malonn is offline   Reply With Quote
Old 06-24-2009, 11:23 AM   #12
MonteSS454
MonteSS454's Avatar
Those are 7 inchers, I didn't see any 5 3/4 inchers.
Old 06-24-2009, 11:28 AM   #13
ARKSTEPSIDE
I HAVE BEEN BOTH A PARTS MANAGER AND GENERAL MANAGER FOR YEARS AT TRUCK DEALERSHIPS AND YOU WANT TO GO TO ONE OF THEM TO PRICE THESE. MOST OTHER SOURCES ARE VERY HIGH AND DO NOT BUY VOLUME FROM TRUCK LITE. MOST TRUCK PARTS DISTRIBUTORS ARE TRUCK LITE DEALERS AND WILL TREAT YOU RIGHT.
ARKSTEPSIDE is offline   Reply With Quote
Old 06-24-2009, 06:44 AM   #14
70GMCer
70GMCer's Avatar
I can think of a lot better things to buy than a pair of $300 to $500 blings......
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 06-24-2009, 07:59 AM   #15
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Yikes... high on the price, but not a bad idea. Give it sometime and the price will come down.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 06-24-2009, 10:54 AM   #16
Naterman35
yeah look at the taillights... when L.E.D lights first became popular they were real expensive... now they've come down alot. You can build them your self to.
There was an awesome write up on thirdgen.org about a guy building a set of tails.
Old 06-24-2009, 03:21 PM   #17
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Expensive sucker huh?
I will stick to my sealed beams I got from LMC.
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 06-24-2009, 06:01 PM   #18
Sammy
Those are expensive. But no doubt in my mind LED tails are the way to go as you can see them much better than the standard bulbs.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 06-24-2009, 06:16 PM   #19
Longhorn Man
on the reduced power comment...
on some cars.... esp small cars like in the 80's... when you'd turn on the headlights, the idle would drop for a moment and then recover. This was due to the amps. Power wise, and MPG wise, you are right, you'd never see the .0001 % gain. However, when selling 200,000 or more cars, the CAFE requirements that are required, that .ooo1$ may be all that's needed.
However, the comment still holds water.
With all major makers working on, or already selling electric powered, or electric hybrids, this is a very important feature. No need to even explain why.
On our old school stuff, you increase the amp load on the headlight wires when you install halogon lamps... which, I think is all you can get. This increaed load burns out switches, and even harnesses. A decreased load will prevent this.
It is benificial to reduce the electrical load used on your vehicle. It just isn't as obviouse as it is in your home.
