![]() Join Date: Jun 2009
Disc brake conversion
Does anyone have instructions (play by play) for putting '73 - '87 disc brakes under my '66 C20? Thank You for any response.
60-66 Nut
Re: Disc brake conversion
That would depend on how you plan to go about it. Are you going to switch the complete crossmember? are you going to rebuild everything in the process? Are you going to add power steering at the same time? what about power brakes? Are you going to lower it at the same time? Lots of questions to be answered before we can help you out.
I honestly don't know if there is a 'play by play' set of instructions for doing this. There used to be a sticky on the subject. It may have made it to the FAQ section somewhere. I'll see if I can find it.
60-66 Nut
I found it and bumped it.....here is the link to it
http://www.67-72chevytrucks.com/vboa...isc+brake+swap
