![]() Join Date: Jan 2002
Ok Im in desperate need of a good trick.it took 4 sawzall blades to get one front spring of my blazer.I put a set of ranchos on a jeep before and burned the bushings out with a torch but these dont seem to want to burn any suggestions will be greatly apreciated
------------------ 1972BLAZER,1966C10SWB,1963NOVASS HOLIDAY,IL
1972BLAZER,1966C10SWB,1963NOVASS HOLIDAY,IL |
If you can locate new bolts, just cut the head and threads off and slide the spring out.
------------------ Pictures and more... Email me '71 LWB 350/350T, PS/PB Special options? Yes, RUST... Need some? Garrett Olathe, Kansas |
thanks ive got new bolts(nla from gm but i found some at an international big ol truck dealer)cutting grade 8 bolts is a real bear unless there is some kind of diamond tip sawzall blade im not aware of.
I was meaning, use the torch to cut the head/thread then slip the spring out. Manual labor isnt good!
![]() ------------------ Pictures and more... Email me '71 LWB 350/350T, PS/PB Special options? Yes, RUST... Need some? Garrett Olathe, Kansas |
I have had good success cutting harden bolts with a die grinder or 4 1/2 angle grinder and a cut off wheel. Torch sure will do it as well Ed ke6bnl
------------------ Ed ke6bnl Agua Dulce 70 S.E. Los Angeles 70 Chevy short bed Sorry 50 F1 pu Sorry 63 Ford Econoline pu
Ed ke6bnl Agua Dulce 70 S.E. Los Angeles 70 Chevy short bed 1948 F3 ford pu 1949 F1 stock V8 flathead 3 on floor 1950 F1 pu street rod 1948 F6 Ford Dually/350sbc no bed stock trans&rear 1972 El Camino 4" chop 1953 Chevy 3100 2b daily driver 1970 SB 4X4 400ci 6in lift |
ill probably try the cutoff wheel tomorrow but im scared to get the torch that close to my shackles ive had to many WOOPS! with the torch before
thanks ------------------ 1972BLAZER,1966C10SWB,1963NOVASS HOLIDAY,IL
Truckin' Krazy
![]() Join Date: May 2000
I have used a skil saw with a metal cut off wheel(cheap at a hardware store) to remove spring bolts in the past, it worked much better & faster than a sawzall. If there's room for it. Good luck
Dealer for: American Auto Wire Precision weatherstripping Dakota Digital Trim parts Carpets Truck World seat covers & Many others Chevy Parts locator in Mesa AZ! |
