06-27-2009, 12:42 AM | #1 |
skinny chevy truck ralleys?
1st off, I hope this is in the right section. I was wondering about skinny chevy truck ralleys. Ive never seen them but would be intrested in some. I think I have a local place to go ask about doing it, but has anyone on here done it already or better yet, sell them?
http://profile.myspace.com/index.cfm...ndid=186313550 Current project is for sale. 4" chop, channelled, lowered 5", http://67-72chevytrucks.com/vboard/s...d.php?t=347067 |
06-27-2009, 12:55 AM | #2 |
TILT COLUMN GURU
Re: skinny chevy truck ralleys?
Van ralleys are skinnier than trucks and look the same as truck.
kevs_classics64 64 Impala SS Conv 72 Blazer 2wd 75 Jimmy 2wd 63 Belair wagon 02 Silverado ext cab. DD RIP EL JAY |
06-27-2009, 01:02 AM | #3 |
I have a full set of 8's, And I know 7's are out there. Im kinda wondering about 4-6" wide. The big and little look.
06-27-2009, 01:17 AM | #4 |
i got 6x 15 on the front of mine with 12x 15 on rear
06-27-2009, 01:30 AM | #5 |
My Carbon Footprint
Stroker......you have car style rallys though.....he is talking about the truck rallys!
06-27-2009, 09:29 AM | #6 |
I have a pair of 4" 6 lug truck ralleys I might part with. They have new rubber on them.
06-27-2009, 09:38 AM | #7 |
I know they made the 15" ralleys in 6.5" (van), 7, & 8 (trucks) widths. I have not heard of or seen any different widths than that from the factory. You can however get them from places like Stockton Wheel and Wheel Vintiques.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 06-27-2009 at 09:38 AM. |
06-27-2009, 10:06 AM | #8 |
Both of these places will make whatever you like. A friend has a pair of 4" he bought from Wheel Vintiques. And they are very reasonable.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
06-27-2009, 10:31 AM | #9 |
Ill check into these. MIght be good enough for what Im doing. Ill also check out the other co's. Go figure I am going to have a little tire clearance issue with this project! Who didnt see that coming. lol.
06-27-2009, 09:46 AM | #10 |
Check The Champ, Demonstrator
I have narrowed and widened rims for myself and for friends. It's easier with more rims than is required. Requires big lathe with a swing more than the diameter of which you are turning .To make a set of narrows save two outer rings from two sets of rims cut off in the lathe. Weld the two rings together then weld in your center. Making them fatter, cut out the center from the inner and outer ring add a piece of flat stock between the outer and inner ring to the dimension desired then weld in your center. The lathe is the secret.
06-27-2009, 12:47 PM | #11 | |
Yeah we made 9.1/2 wide ones doing it exactly like you sad. |
