Inner fenders?
Does anyone know if any companies make plasic inner fender wells, or something other then steal? Looking for a little weight reduction and not having to worry about them rusting out.
1969' LWB [Work in Progress] |
![]() Join Date: Nov 2002
I wish I knew that too.
I had a '68 SS Chevelle once. It had steel inner fender wells. My '69 Malibu, however, had fiberglass ones.
Jeff '67 short Fleet; my ongoing project. '66 long Fleet; my original "baby." Live life or bust trying. |
GMC SHORT FLEET F/S
Plastic ones would be nice but I have not seen any?
CHARLES WADE HEIN HVACR FOREMAN. LEWISBURG U.S.P. |
someone makes fiberglass ones it was in a post a while backI will see if I can fiond it.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Seņor Member
USbody.com is who makes the fiberglass inner fender wells, but they are not too cheap. I'm looking for plastic but I don't think anyone makes them. Someone should though!
#7 | |
Seņor Member
Re: Inner fenders?
USBODY 109.00 each? are you sure? I just spent the day upgrading their parts in our catalog and they are 169.00 in their catalog, 149.00 in ours. Are they doing a special on these that they forgot to tell me about?
Rest in Peace Ed. Thanks for all the good times. |
#9 | |
Where's my beer?
Paul How do you make the invisible, visible?.........You take it away. |
I believe thats a goodmark part number for the steel inner fender. The same fender in most catalogs for 80-90.00. The usbody part number is FCGW-72.
Bloo
67-72 Front Wheel Well/ea FCGW-72 $ 169.
thats the glass one http://www.usbody.com/67-72%20chevrolet%20truck.htm |
1969 Custom 30 wrecker
The steel repro's aren't very heavy by any means. I couldn't imagine saving much weight with another type.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
![]() Join Date: Jun 2002
Chevy Duty has them for $ 119.95 Here are the part numbers in case you need.
37-475 Left,Fiberglass 37-476 Right,Fiberglass These are sold in pairs only and are gel - coated gray. Ready for finish sanding . Hope this helps!! Later Chris ![]()
![]() click here to see my buildpage http://67-72chevytrucks.com/vboard/s...d.php?t=394656 ---------------------------------- 1979 C10 Silverado Big10 SWB Factory 454/400 Cardinal Red/Santa Fe Tan (original paint) 1969 Camaro X44 LS swap 1968 C10 SWB Fleetside (SOLD) 468BBC MultiPort TPI / Dynamic EFI P4 Black/Black 1963 Nova SS convertible (SOLD) 194 I6/ PowerGlide |
There is a "glass man" near Washington PA named Henry Cassidy His Company is Fibercast Products 724-225-8690. He makes all sorts fo fiberglass tubs and showers, but he also sells 67-72 parts from the south. And he makes glass inners, stepside outers, and other parts for our trucks. I had a set of his inner fenders but sold them. He sells at all the local swap meets. I am VERY sure his are way less than $100 each, Good luck
'96 GMC Suburban 6.5t '99 F**d Windstar '07 SON '09 DAUGHTER XOXOXO Wife |
#15 |
love my truck
I have a set of fiberglass inners on my truck. I bought them in Owen Sound, Ontario, Canada. The place is called McMillan Fiberglass and the number is 519-371-0579. I paid $150 each (Cnd.). They fit well, look good. I had to make my own holes to mound them on the fenders. Hope this helps.
#16 |
I don't think you would save much weight by using plastic or glass. Besides, i ahve some aftermarket steel ones that just do not fit. I can't imagine how horrible glass or plastic would be.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
#17 | |
Seņor Member
#18 |
More then saving weight I just don't want to mess with the repro not fitting and the steel rusting out. I was just checking out options for inners.
#19 |
My repro's went right in with no problem. I painted them with a high quality paint/primer/sealer and undercoated the inner sides. They aren't going anywhere for at least 30 years!
With plastic or fiberglass, you have to worry about cracks or breaks and I've never seen one that fit right. I like the fact that my truck is made of metal, that's one of the reasons I own only old cars/trucks. I say let the plastic for the newer cars where it belongs! LOL ![]()
#20 |
XXL no problem it happens to me all the time, we put them in our catalog for 149.00 and steel for 80.00. USBODY has very high quality fiberglass parts and i'm very happy they took me on as a dealer.
