My 60 Chevy Shop truck build
I just bought a 60 Chevy short /narrow Pick up. It is a little rough. I Know I have a 59 Fleetside build thread in the 47-59 board. But since that is more of a high dollar build, I kind of put it on the back burners. This truck(the 60), is running a Mr Goodwrench Vortek engine with a Holly 600. Saginaw 4speed, and the original rear (super low geared, have to change). Here is what it looked like when I first got it.
![]() The first thing I did was replace the newer hood with the proper 1960 hood. ![]() As you can see in the second picture I already welded the rust on the doors and fenders. next it was the rockers and floor boards. these had to be replaced with new parts. ![]() ![]() I got one rocker installed, will update as I continue. ![]()
1961 GMC Suburban Custom 1969 Short wide project http://67-72chevytrucks.com/vboard/s...d.php?t=535479 (SOLD) 1959 Apache fleetside (frame off in progress) http://67-72chevytrucks.com/vboard/s...d.php?t=348746 1960 Apache short/narrow shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=350780 (SOLD) 1951 Plymouth leadsled project 2005 Corvette conv. Procharged 1969 Corvette stingray 2006 Cadillac XLR-V 1950 Oldsmobile 98 custom project |
![]() Join Date: Sep 2006
Re: My 60 Chevy Shop truck build
You move fast... good for you.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
Not that fast, I've had it for about a month. I just ordered new cab corners and rear bed steps. I tried to fix the small holes in the cab corners, there was no good metal to weld to. Good thing parts a pretty cheap for these trucks.
60-66 Nut
Welcome to the dark side as we call it.
![]() I see you installed the outer rocker first.....I've been doing that last. I'm curious to see how the floors and inner rockers go for you doing it this way.
The inner and outer are installed together (boxed in as in pic if you look closely). I installed them first to give me something to weld the floorboard to. The rockers are a direct replacement, while the floorboards have to be trimmed to fit. I don't see how you could do it the other way around. I actually completed the both sides just no pictures yet.
Resistance is Futile
Nice work frmula505. Glad to see yet another 60-66 goin here. Got a link to your fleetside build? Im a huge fan of the 58-59 fleetsides.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
283 Drama Queen
![]() Join Date: Dec 2004
Great start - and WELCOME to the loony bin!
![]() Mac. ![]()
For about 12 years of my adult life I had a severe speech impediment. My ex-wife never let me get a word in edgewise. |
Just here to tinker
![]() Join Date: Jun 2008
Kick a*s! Glad to see you put the Eyebrow hood back on!
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
Here is the link to my fleetside build
http://67-72chevytrucks.com/vboard/s...d.php?t=348746 I finished the flood boards. I used the trim style floor pieces. I used the original mounts section and just covered it with the new parts (the mount section wasn't rusted bad) I cut off the bad metal, the coated what was left with Eastwood rust stabilizer before I tacked the patches on. Then used seam sealer to finish it up. ![]() I found a little more rust on the hood. Welded that up and did some body work. ![]() ![]() Got one of the fenders almost ready. ![]() I haven't got the cab corners in yet, thats next.
Got a little more work done this weekend. Finally got the cab corners fixed. Welded just enough to fix the rust ( stayed with a lot of new steel that wont go to waste). Found some lead work that had been done on the passenger side.
![]() ![]() Here is after the initial body work. Still needs the final blocking and to clean up the bottom edge. ![]() ![]() Also found a little rust on the rear fender when I removed the stepside. ![]()
1961 GMC Suburban Custom 1969 Short wide project http://67-72chevytrucks.com/vboard/s...d.php?t=535479 (SOLD) 1959 Apache fleetside (frame off in progress) http://67-72chevytrucks.com/vboard/s...d.php?t=348746 1960 Apache short/narrow shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=350780 (SOLD) 1951 Plymouth leadsled project 2005 Corvette conv. Procharged 1969 Corvette stingray 2006 Cadillac XLR-V 1950 Oldsmobile 98 custom project Last edited by frmula505; 08-17-2009 at 11:54 AM. |
1962 C-10
Looking good Jose! We are expecting a package of door patch panels this evening. Ever done door patches?
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
Hollister, CA.
Nice man....
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
I repaired both my doors with doner metal.
Just here to tinker
Man, those cab corners are flawless. Excellent work!
#15 |
Nice work!!!
#16 |
A little spare time after work yesterday. Got the lower rear fender (rust ) repaired
![]() And put together the chrome grill I found on line. I found the grill and headlight bezels at a truck junk yard in MN. I replaced the headlamp adjusters on my old headlamp assemblies. I haven't decided what color to go with the center bars. Either silver (stock color) or the color I'm painting the truck. ![]()
#17 |
283 Drama Queen
#18 |
Got some work done these last couple of days. I started on the area below the rear window. Boy did it have a lot of dents. 50 years of work will do it.
![]() ![]() With this, and all the sanding and dings around the grill opening. It looks like my cab is ready. (except for the small ding I found at the center of my hood Where the chevy emblem goes) ![]() ![]() I have the three cowl pieces sealed and ready also.
#19 |
1962 C-10
Nice work!
#20 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Looking good.
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#21 |
"Where were you in '62?"
![]() Join Date: Jul 2004
Boy does that bring back memories....
Still gotta take care of my doors! Nice work!!!!! Keep us Posted! ![]()
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
#22 |
Zero Albedo
Damn nice truck!
Nice skills as well! Every time I see one of those early Chevy snorkel hoods, I like them more and more.
Baz "Deserve's got nothin' to do with it." 66 GMC 1500 wideside longbed 250 4spd "Project Rekker"http://67-72chevytrucks.com/vboard/s...d.php?t=467467 65 GMC 1Ton Panelhttp://67-72chevytrucks.com/vboard/s...32#post4794432 65 Chevy Panel (former U.S.Navy truck) 64 Chevy Suburban Carryall 4x4http://67-72chevytrucks.com/vboard/s...d.php?t=358348 64 GMC 1000 wideside longbed 305 4spdhttp://67-72chevytrucks.com/vboard/s....php?p=3600890(Rip- parts truck now) 68 Dodge Charger |
#23 |
Watchin this one come together..
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile |
#24 |
![]() Yep.............
She's coming along good...... She could be here soon frmula505..............
#25 |
daym you do work fast! look'n good!
