Old 06-29-2009, 05:49 PM   #1
jeremiah king
jeremiah king's Avatar
front end help
have 68 3/4 ton longbed, switch to 71 72 disc brakes . problem drivers tire
1/4in from hitting sway bar. when turning to the right. turn to the left pass tire is 4in from the sway bar. and turning it drags the tires.. second problem
in lots of sway in the the front end at speeds of 50 and higher. had the front end align. please help
jeremiah king is offline   Reply With Quote
Old 06-29-2009, 06:06 PM   #2
71tahoe
71tahoe's Avatar
Re: front end help
Sounds like one problem may be that the steering box might have not be centered from lock to lock before the pitman arm was attached.
Also, was this a 3/4 to 3/4 or to 1/2 ton?
71tahoe is offline   Reply With Quote
Old 06-29-2009, 06:12 PM   #3
jeremiah king
Re: front end help
3/4 drum to 3/4 disc. we centered the pitman arm, still have the problem. any other ideas
Old 06-29-2009, 06:36 PM   #4
71tahoe
71tahoe's Avatar
Re: front end help
I know you said it was aligned but the only other thing I can think of is that maybe the springs aren't properly seated.
