Old 06-30-2009, 03:46 PM   #1
brak
brak's Avatar
Frame Rivets
so, after two years, i've finally got around to prepping the frame i got from LockDoc (removing manual trans crossmember, and installing C-Notches), and all these rivets are driving me absolutely batty...
basically i've been cutting a X in the head, and then using a hammer and chisel to break the pieces off...
There has to be an easier way to accomplish this task...
any suggestions?
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 06-30-2009, 03:55 PM   #2
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Re: Frame Rivets
air chisel - should cut thru those puppy's in a big hurry
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 06-30-2009, 04:03 PM   #3
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Re: Frame Rivets
That's how I did mine.
after you put the X in it.
LOW DOUGH is offline   Reply With Quote
Old 06-30-2009, 03:59 PM   #4
John Fabris
TOTY 2006
John Fabris's Avatar
Re: Frame Rivets
That is close to what I do. I drill the middle of the rivet head out, then a few taps with hammer/chisel to remove whats left of head, then hammer/punch to remove rivet.
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 06-30-2009, 04:09 PM   #5
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: Frame Rivets
i grind the head flush, then use a BFH and a punch
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 06-30-2009, 04:19 PM   #6
BigCarl
Re: Frame Rivets
Take a BFH and a punch he says...
A little closer...
Oh, and here is my dog.
I cut an X into mine, ground them off.. all of them... all of them... all of them... *sigh*
Then punched them out.
I replaced them with Grade 8 bolts, washers, lock washers and nuts.
Good luck man, and where gloves like I should have.
BigCarl is offline   Reply With Quote
Old 06-30-2009, 04:26 PM   #7
john
member #16
john's Avatar
Re: Frame Rivets
A little closer...
That wont happen if you have the wife hold the punch.
john is offline   Reply With Quote
Old 06-30-2009, 04:42 PM   #8
brak
brak's Avatar
Re: Frame Rivets
and that is exactly why i'm divorced now....
she was tired of holding the punch
seriously though, i've tried using my air chisel, but i don't think my compressor has the capacity nor cfm necessary.
thanks for all the input, and if i never see another rivet it'll be too soon
Old 06-30-2009, 04:49 PM   #9
john
member #16
john's Avatar
Re: Frame Rivets
I drill about a 1/4" hole and whack it with a chisel and they pop off. also they punch out easy when you relieve them.
Old 06-30-2009, 04:14 PM   #10
craig24671
craig24671's Avatar
Re: Frame Rivets
I agree I grind the head flush and then punch them out quick and easy
Spanky
craig24671 is offline   Reply With Quote
Old 06-30-2009, 04:46 PM   #11
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Re: Frame Rivets
try putting one more line in your X, then use the air chisel. I had to do that a couple of times.
Old 06-30-2009, 08:30 PM   #12
lchall
Re: Frame Rivets
The best way I have found is to get a GOOD resin fiber disc and angle grinder to grind the heads completely off, somewhere around 24-36 grit. It only takes about 15-20 seconds to grind the entire head off with a good disc. I started off with x-cuts and an air chisel, but this was MUCH easier to do.
Then I used an air hammer with a punch to drive the rivets out. This works probably 90% of the time, but occasionally you'll need a monster hammer and punch to get some stubborn ones out instead of the air hammer.
1967 Chevy SWB
1972 Chevy SWB
1972 Chevy SWB K20 4x4
1991 Ford F-150
2013 Dodge Ram 1500 4x4
lchall is offline   Reply With Quote
