06-30-2009, 09:43 PM | #1 |
a/c blows fuse when on high
This has been a pain in the a$$ for the past few days.
My a/c works great until you put the fan switch on high and the the fuse blows. I have checked the relay,fan switch and they are fine. Any suggestions ? thanks |
06-30-2009, 09:57 PM | #2 |
profeshinaly unimployed
Re: a/c blows fuse when on high
are u sure u have the right sized fuse? i use to have the same problem with my stereo in my old truck till i found out the fuse wasn't the right size
"having mud flaps is like asking for a smaller trophy" |
07-01-2009, 10:07 AM | #3 |
Robert Olson Transport
it shouldnt take more than a 30 Amp fuse for the AC ..if the relay checks good id start searching the wiring for something that arcs
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
07-01-2009, 03:52 PM | #4 |
yeah, a 30 amp fuse is more than enough for the blower circuit, most times this can be traced to a blower motor that has to high of an amp draw on high (this happens when it is old and the brushes are really close to the commutator)... same thing with a/c cluthes, if it is close to worn out and the gap is too big on the clutch, it will draw too many amps and pop the fuse... hope this helps
be a site supporter |
07-01-2009, 05:16 PM | #5 |
Could be debris in the fan. Pull the motor and clean it out. Would be a good time to oil the motor shaft and make sure it spins freely. Also check the speed control resistors inside the airbox. I have seen them blow up or short together. That usually kills one of the intermediate speeds though.
- Greg |
