Need 1970 Blazer 2wd swap advise
I have a 1970 Chevy K5 4x4 and would like to remove the 4x4 front suspension and axle to replace w/ 73-87 1/2t Chevy 2wd suspension. I know I have to remove and replace the front cross members but not to sure how to line up and install the 2wd crossmember for a perfect fit and alignment. Any advise is greatly appreciated
![]() Join Date: May 2002
Re: Need 1970 Blazer 2wd swap advise
welcome to the board.
lots of people have done this conversion, just look in the Builds sub-forum. to answer though, there should be several holes in the frame where the crossmember would line up. there will be 2 holes that you will have to elongate in the frame to accommodate the new crossmember. good luck with it, and post some pics when you get a chance.
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD ![]() Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
If you have to deal with a different drive shaft, I'd use the opportunity to move the engine a little forward in the engine bay.
Tony Johnson -- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer -- |
![]() Join Date: Apr 2004
I have not done this, but I've read that the 2wd crossmember will bolt right up with the exception of 2 holes that will need to be drilled.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
I just did this conversion and found the rear 2 outside frame holes line up then I had to drill the other 10 holes.my build is prostreet/dragrace blazer and has some pics of this. Good luck and this is fairly straight foward.I have lots of pics and time if you need a answer or advice.
what 2 outside frame holes are you referring to?
Thanks |
is the 73+ front cross member identical to the 67-72 units? swapping the setup into a 50's gm you have to narrow the crossmember to get the correct track width and line up with the frame rails. comparing my 72 burb to my dad's 87 burb 2wd it looks almost the same even though my truck is a 3/4 ton.
