Closed Thread
Old 07-01-2009, 09:50 PM   #1
PBFAB.COM
PBFAB.COM's Avatar
Porterbuilt- Dropmember V3.2 & Control Arms- Till July 31
The Dropmember V3.2 is the latest addition to the Dropmember family! It’s round tube structure, strengthened and accented with CNC cut plate make it both structurally rigid and aesthetically pleasing. Other advantages of the new design include: a significant weight savings of just over 10lbs. from it’s predecessor ; and a sleeker, more custom appearance. The Dropmember V3.2 is constructed of 1.5” DOM tubing and .188 pickeled plate. Available for the C10 chassis years 1960-1987.
Dropmember V3.2-
Dropmember V3.2 Stage I kit-$1099 (and free shipping anywhere in the continental U.S.)
Stage I kit includes main crossmember, inner frame support plates, upper control arm/bag mounts, motor mounts (SBC, BBC, LS1, I6), upper shock mount relocators, tubular transmission crossmember, frame notches for rack and pinion clearance, billet rack mount bushings, billet tie-rod ends with hardware, all necessary hardware for kit installation, and instructions via e-mail.
Dropmember V3.2 Stage II: $2100-
Includes Stage I components, plus upper and lower tubular control arms (add $100 for 4130 Chromoly upgrade), ball joints, delrin bushings, billet upper cross-shafts.
Dropmember V3.2 Stage II kit-
Dropmember Control Arms-$1099
(offered in DOM tubing or upgrade to 4130 chromoly for an additional $100)
Complete set FREE shipping anywhere in the continental U.S. (Includes upper and lower control arms, machined Delrin bushings, billet upper cross-shafts, and ball joints)
Porterbuilt Street Rods is now offering it’s own line of C10 control arms to be used with the Dropmember, or factory C10 crossmember. The arms have been designed to work with either factory 73-87 control arm bushings, or machined Delrin bushings offered through Porterbuilt. Factory replacement ball joints from 63-87 press into the lower arms, and bolt-in to the uppers. Ball joint angles have been corrected, and additional caster added
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline
Old 07-03-2009, 12:46 AM   #2
abadsvt
abadsvt's Avatar
Re: Porterbuilt- Dropmember V3.2 & Control Arms- Till July 31
WOW Nathan!!!!!! i absolutely love the new version. Especially how the round tube on the dropmember ties in (aesthetically) with the control arms perfectly! Bravo nate!!!!!!
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline
Old 07-03-2009, 10:54 AM   #3
AVS_JASON
AIRBAGPARTS.COM
AVS_JASON's Avatar
Why couldn't you've had this new one available when I ordered mine? LOL... Looks amazing though...
AVS_JASON is offline
Old 07-06-2009, 04:43 PM   #4
Kontrol Phreaks
Kontrol Phreaks's Avatar
Very nice as usual Nate.
- Clint -
Kontrol Phreaks is offline
Old 07-06-2009, 05:38 PM   #5
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
That is sweet looking Nate. Good work on the tubes.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline
Old 07-13-2009, 11:01 PM   #6
Ronm909
67GMC Slammed
Ronm909's Avatar
does this dropmember work with stock control arms? if it does I am ordering!!!
Ronm909 is offline
Old 07-13-2009, 11:06 PM   #7
PBFAB.COM
PBFAB.COM's Avatar
Factory lowers from 73-87, Factory uppers from 63-87.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 07-13-2009, 11:22 PM   #8
Ronm909
67GMC Slammed
Ronm909's Avatar
dont know if there is a differnace but I have upper and lowers from a 88 suburban, I was told that suburbans 88-92 are the same as 87 trucks... the whole crossmember pretty much bolted to my 67 frame..
Ronm909 is offline
Old 07-13-2009, 11:43 PM   #9
PBFAB.COM
PBFAB.COM's Avatar
The 88-91 suburbans carried over the C10 front suspension. The suspension changed on the burbs in 92 when the body style changed. Those arms will bolt up just fine. The upper arm will have to trimmed a hair around the stamping where the bushings press on at the rear of the arms for clearance at the frame... just a little bit.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 07-14-2009, 09:56 AM   #10
joe231
joe231's Avatar
quote from Wikipedia
"1973 - 1991 - "9-passenger seating"
Starting with the third generation C/K models, the Suburban was finally a 4-door vehicle. The rounded corners 1970s body style remained largely unchanged for 18 model years - making this series the longest in production of any Suburban."
"1992 - 1999 - GMT400
The GMT400-based Suburbans were introduced in the 1992 model year. This was actually quite late compared to their pickup truck brethren - which switched platforms in the 1988 model year. Both 2WD and 4WD models, again designated "C" and "K", were offered, as well as half ton and three-quarter ton ("1500" and "2500") models."
just wanted to clear that up
Carry on.....
CHEVY ONLY
joe231 is offline
Old 07-14-2009, 04:07 AM   #11
wancosc356
I Like Mine With No Shine!
wancosc356's Avatar
With the stage 2 kit, what else is needed besides the rack and pinion, shocks and bags? Is this system already setup to accept bags or will I have to modify? Is powder coating included in the price?
Michael
1967 Chevrolet C10 Short Fleet (Literal Ground Up....One Day)
2006 GMC Sierra Crew Cab 4x4
1969 Lincoln Continental Coupe Project FOR SALE
http://67-72chevytrucks.com/vboard/c...ct=4578&cat=17
1981 Honda CM400 C Bobber SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=384152
wancosc356 is offline
Old 07-14-2009, 09:06 AM   #12
Tony@AirRideTech
Junior Member
1 ton Dropmember with big block mounts that will take my arms????
Tony@AirRideTech is offline
Old 07-14-2009, 09:11 AM   #13
PBFAB.COM
PBFAB.COM's Avatar
"Your arms" as in ART arms? or factory arms? The factory one ton arms will not bolt up to the DM, but the Strong Arms will. I can build you a set of lowers for the 1 ton ball joint, or modify a set of the Strong Arms if you are wanting to maintain the 1 ton spindle.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 07-14-2009, 09:30 AM   #14
Tony@AirRideTech
Junior Member
Def maintaining the 1 ton spindle. Truck still gets used as a 1 ton. I can modify the arms here for the correct ball joints... Ill give you a shout in the next couple of days and see if we can get something together for this winter tear down.
Old 07-14-2009, 09:13 AM   #15
PBFAB.COM
PBFAB.COM's Avatar
This system is designed specifically for air suspension, and the air bag will bolt right up.
If you already have control arms/spindles/and brakes, all that is left is the steering rack, bags and shocks.
Powdercoating is NOT included in this price.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 07-19-2009, 10:03 PM   #16
Mello Mel
African-American Shaolin Monk
Still no rear setups for the k5 blazer ? I am sooo dissapointed.
Mello Mel is offline
Old 07-19-2009, 11:38 PM   #17
PBFAB.COM
PBFAB.COM's Avatar
Working on it! Or let me re-phrase that... working on getting to that project! It will most likely be a little bit longer. I need to finish the trailing arms (extremely close) and then the hood hinges.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 07-28-2009, 03:36 PM   #18
bama51
Are you working on 67-72 hood hinges? Forgive me if that info is posted elsewhere, I just saw that you were working on "the hinges". If you are, post some details or point me to it. I'm extremely interested in ANYTHING different.
bama51 is offline
Old 08-01-2009, 08:24 AM   #19
67cheby
67cheby
67cheby's Avatar
Hey Nathan someone on this site said you have a sway bar that will work with the strong arms i would like to buy one if you could give me a call Mike 1 479 599 9664
67cheby is offline
Old 08-01-2009, 01:07 PM   #20
PBFAB.COM
PBFAB.COM's Avatar
Yes I am. I have been extremely busy filling orders on the other products, and trying to balance the development of new ones. I just buttoned up the final touches on some dropped trailing arms, and am now getting back on the hinges. Look for some pics this month!
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 08-01-2009, 01:32 PM   #21
SCOTI
SCOTI's Avatar
Nate
You're killing me buddy .
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is offline
Old 08-07-2009, 07:16 AM   #22
sgrier
Got my complete front and rear dropmembers on order. Thanks Nate, just waiting on the UPS truck.
sgrier is offline
Closed Thread
