Old 07-02-2009, 11:14 PM   #1
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Wing or vent window rebuild
I am finally getting around to getting this together. For now it will just be the teardown. I will finish up mine and post some pics of the steps taken hopefully within a week. If you can't wait til I do that, just reverse the tear down. I'm not going to list part numbers because there are several vendors that carry the items needed.
Parts needed
Vent window rebuild kit (it comes with the rivet tool)
Window/door weatherstrip kit (it's generally cheaper to get everything together)
New vent window latch (if needed)
I will leave the tool choices up to you.
Most important is to make sure the pin that is in the glass channel that the latch pivots on is in good shape and not missing. As of right now there is not a repair kit for it.
Step 1
Remove roll pin from latch handle and remove handle and spring washer (picture above) and inspect pivot.
Step 2
Measure how far the stud sticks out from the nut. Then spread out lock washer. Notice the placement of washers. The flat part of the top washer that is like a triangle goes towards the front.
Step 3
Drill out pivet rivot
This is the placement of hardware (Pay attention to orientation make notes. Be sure you install everything right before you install the pivot rivot. If the washers are not installed correctly the window will not open right.)
Step 4
Grab the top of the window and pull it out of the track. I've been told by Tim Christian that all of the glass from 60-67 does not have a hole in it where the lever goes. 68 and up has a hole with the lever pivot pin goes thru the glass. I've removed 5 glasses and they all come out easy since the rubber is dry rotted.
Step 5
Remove rubber from channel that holds glass in.
Step 6
Remove the main vertical weatherstrip that the door glass goes up and down in.
Drill 4 rivets on the vertical rubber and remove.
Step 7
Remove the rubber that the glass seals against. Grab one end and pull out. It comes out pretty easy depending on how dry rotted it is. Nothing holds it in place except for itself. The rubber squeezes into the channel.
Step
Alan's Classic is offline   Reply With Quote
Old 07-02-2009, 11:33 PM   #2
Alan's Classic
Re: Wing or vent window rebuild
EDIT: go to post 69 for the second one I did. The weatherstrips were installed in a different order. Feel free to read thru the rest of the post, just want to inform you of what worked best for me.
This a picture of the rivet tool. The short one came in my kit. I had one already that was longer and seems to work alot better. It's easier to hold on too. Getting a straight shot on the rivet is really a challenge, but can be done. I had even thought about removing the hoop from the verticle bar just to install the 4 rivets the reinstall the hoop. I have not tried that yet.
I cleaned, primed and painted one of my frames
I then taped it up to protect the paint.
I mounted the punch in the vise to back up the rivet while I used the rivot tool to flare the rivet. It is a 2 person job.
This is what I did wrong on my first one. I installed the short verticle piece first Don't do that install the rubber around the hoop first. Then install the short piece.
Done so I thought.
I thought there was a repair kit for the handle pivot. I even thought I had it. I was wrong. I have to replace the glass frame.
Old 07-02-2009, 11:54 PM   #3
protrash64
Resistance is Futile
protrash64's Avatar
Nice work Alan, and thanks for diving in first! My vents are starting to look better the way they are....J/K.....I've had the stuff to do this for years and will be doing it this summer.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 07-02-2009, 11:46 PM   #4
bubba327
HOW long until spring??
bubba327's Avatar
Thanks for the pictures Alan. I just replaced both all the window regulators , rubbers and felts on my '64 in May. I found that a piece of 3/8 wide steel flat bar in the vise lengthwise was a helping hand and an anvil. I was never quite happy with the set tool. There has to be a better way.The hinge pivot rivet is maddening!! PS; you can spray undercoating inside your door frames while your window is out and your arm will fit in!!
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 07-02-2009, 11:53 PM   #5
terd ferguson
terd ferguson's Avatar
Thanks. Good thread.
"I never apologize. I'm sorry, but that's just the way I am." - Homer J. Simpson
1955 2nd Series Chevy "King Of Trucks"
terd ferguson is offline   Reply With Quote
Old 07-02-2009, 11:55 PM   #6
Alan's Classic
Thanks for the tips. I wanted to do what you said with the flat bar as an anvil, but the rivet is recessed in the hole. I thought the rivet wouldn't tighten up. Did you have any issues with that?
Old 07-03-2009, 12:02 AM   #7
daverod
SSN 706
daverod's Avatar
On that spring picture I think I can actually see the rust molecules.
daverod is offline   Reply With Quote
Old 07-03-2009, 12:12 AM   #8
Alan's Classic
Old 07-03-2009, 12:18 AM   #9
Joemomma1
Joemomma1's Avatar
Thank you!! I was trying to figure this out. I want to chrome that metal piece but could not figure it out. Thanks.
Joemomma1 is offline   Reply With Quote
Old 07-03-2009, 12:08 AM   #10
bubba327
bubba327's Avatar
Alan -I started the rivet with the set tool, then 1 hit with a big center punch to flare it out, the finished it with 1 hit using a ball punch to tighten it up. All finished tight and recessed back in the felts, but I sure wish I had a clamp or something that held both sides and could be hit with a BFH on the anvil. Something like a blacksmith's swedge block. Maybe even a C-clamp which tightened, spreading and flattening the rivet.
Old 07-03-2009, 12:11 AM   #11
Alan's Classic
Old 07-03-2009, 01:40 AM   #12
1964C10
1964C10's Avatar
Thanks for the great write up Alan!
1964 Fleetside LWB
1995 Yellow Mustang convertible
1996 Camaro Z28
My build thread
Looking for help on completing the Disc Brake Upgrade Reference Thread
If you didn't build it, you don't really own it
1964C10 is offline   Reply With Quote
Old 07-03-2009, 07:25 AM   #13
ol Curt
Junior Member
ol Curt's Avatar
As always, your post deserves a sticky. Great job Alan!!
1966 Chevy C10 Longbed
I'm Bob....ol Curt was my Grandpa
The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down!
ol Curt is offline   Reply With Quote
Old 07-03-2009, 07:57 AM   #14
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Great post, exactly what I just did on my 61...'cept I chopped mine down 3 inches in the process
Old 07-03-2009, 09:06 AM   #15
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Nice work Alan...Great pics !!!
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 07-03-2009, 09:58 AM   #16
MacAttack
283 Drama Queen
MacAttack's Avatar
THANK YOU, ALAN!
This is exactly the thread I was looking for. Joe - again, take note of the real photographs, and, go to Wal-Mart: two Fugi cameras for less than nine bucks.
Mac.
(PS - Alan, I'd give you some more points, but the system won't let me.)
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 07-03-2009, 11:26 AM   #17
protrash64
protrash64's Avatar
[QUOTE=
(PS - Alan, I'd give you some more points, but the system won't let me.) [/QUOTE]
X2....I just keep rating your threads excellent.
Old 07-03-2009, 11:38 AM   #18
Chevy Fleetside
Chevy Fleetside's Avatar
Lookin good Alan.... When I did mine I just used pop rivits. They also work but not factory.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 07-03-2009, 11:51 AM   #19
Alan's Classic
X3
Thanks Jon, I was wondering how yours is coming along.
Originally Posted by MacAttack View Post
THANK YOU, ALAN!
Mac.
Damb system, J/K I love this system.
Thanks, I was wondering how they would work.
Got my other window frames sandblasted today at work. Once I get them painted I'll do a write up on putting them back together.
Old 07-11-2009, 10:15 AM   #20
mbgmike
If you are doing alot of these this is the tool we sell and use to set the revits. If doing just one its not worth the money but they do a profesional job.
cuts time to do to seconds not minutes.
mbgmike is offline   Reply With Quote
Old 07-11-2009, 03:25 PM   #21
Alan's Classic
Thanks for the tip.
Old 12-16-2012, 01:51 PM   #22
madchopper
Mike:
What is the name of the tool and where can it be found?
madchopper is offline   Reply With Quote
Old 07-11-2009, 03:58 PM   #23
joe231
joe231's Avatar
so when you buy the rivets it comes with the pivot rivet
sorry it is a serious question, it just sounds funny saying it out loud
very nice work and write up!!
how much for the tool, and do you have a link?
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 07-11-2009, 06:42 PM   #24
CSoliz
Torn between 66 and 78
CSoliz's Avatar
Alan, what kind of paint and primer did you use. Also, what did you do about the strike plate for the latch handle while painting? did you leave it and tape it off or take it off?
CSoliz is offline   Reply With Quote
Old 07-11-2009, 07:36 PM   #25
Alan's Classic
Thanks Joe. The kit I got only had 2 pivot rivets and had plenty of the others. Since I have to disassemble the one I had put together to replace the glass channel. I had to get another rivet. Tim Christian came thru for me on more rivets.
PPG K38 primer and PPG single stage black and I taped off the latch plate and the chrome beads on the main channel.
