07-03-2009, 09:25 PM | #1 |
landarts
New seat cover - Make it new with picts
What I have here is a 72 LWB Cheyenne . I am in the process of rebuilding the seat and thought possibly someone could use this information. First let me say that I pulled the seat out of the truck and disassembled the seat by first cutting off all hog rings then removing the old factory stock seat cover. After I removed the seat covers I pulled out all of the seat cover wires and laid them on top of the old cover in their respective locations. Then I inspected the springs and the bottom support and top support area. What I found was all springs were in great shape except for one spring on the bottom support had snapped out of its holding place and was missing about 1/2" of the spring area that slips thru a holding slot. So I clamped down the spring in that area and welded to the location.....took about 3 minutes from the time I pulled out the welder. Then after closer inspection I found a little grease and roughly unpainted areas on the frame. I then removed the grease with some degreaser, washed off the entire frame with soap and water then let dry. Set everything up out in the yard to give it a couple of light coats of gloss black spray paint. I let everything dry over night.
Day two I went to the local fabric store and purchased a product called (Nu-Foam) in the 1/2" size, it is a non-allergenic foam substitute that is easy to work with and cost about $6.50 a yard. I also purchased a product called "Heirloom" cotton batting, it comes in various sizes. I purchased a bag that was 90" x 108" . When I got back to the house I laid the seat cover out on the fence to get it heated up and make things a little more pliable to work with. I laid the Nufoam on a table and put the bottom seat foam upside down and traced the top of the seat out on the foam and proceeded to cut it out. Then I put the bottom support up on the table, put the foam bottom of the seat on top of the frame and the newly cutout of Nufoam on top of the old foam. Everything looked great from there. So I proceeded with the Heirloom cotton batting layer on top of the entire seat cushion and let it hang down low all the way around. I also had a few scrap pieces of Nufoam that I positioned under the springs on both ends ( see Picts). The reason for this was the springs in those location had really wore that area of foam and I thought this would give it a new area of support for the springs. Now was the time to pull the new seat cover over the assembly of old and new foam and give it a test sitting before I moved on to the stretching and fastening. It felt perfect, not overly plump but firm in all locations. See next post for the final product. |
07-03-2009, 09:36 PM | #2 |
landarts
Re: New seat cover - Make it new with picts
Part Two
I also had painted all of the seat wires do to them being somewhat rusting. I used the same gloss black spray paint that I used for the frame. I pulled the bottom cover over , stretched and fastened as I went along working from the center points to the outer. Seat bottom cushion completed. Moved onto the back cushion. This foam was in excellent shape so I wrapped the entire back rest of the foam from the bottom that goes against your back , up and over all the way down to the bottom of the backside of the cushion (see Picts). By doing this it left a really clean fabric on the backside instead of the old aged foam. Pulled the seat cover over the entire cushion and trimmed any excess of the bottom area after smoothing out. I moved forward with fastening and stretching the seat cover to release it of any wrinkles of lose areas. I then put the seat back up in the location to fasten all the newly painted bolts and secured it down firmly. I had to give it a test drive in the garage and see how it all felt. Good to go! Seat cover was purchased thru LMC NuFoam and Heirloom cotton batting purchased from House of fabrics. |
07-03-2009, 09:47 PM | #3 |
Its Topless Season!!!!
Nice write-up...looks real good.
07-03-2009, 10:35 PM | #4 |
Between Trucks...
Nice work, seat looks great.
Beat it to fit, Paint it to match... |
07-04-2009, 01:26 AM | #5 |
BlahBlahBlah
I did my seats today too. Yours looks very nice. My hands hurt some from pulling everything taught with one hand and trying to hog ring with the other.
07-04-2009, 07:36 AM | #6 |
landarts
I believe the hurting hands come with the job, along with a little foul language and then some gentle persuasion.
07-04-2009, 09:19 AM | #7 | |
Fat Fendered Fleetside
Nice job. looks good, should look better in a week or so:
For all you guys that might not know, any little wrinkles in the cover will almost always come out once the seat is in the truck/car and set out in the sun for a few days. The heat in the cab will let the foam pads and cover stretch and relax in all the right spots for a nicer fit. Working auto upholstery, some picky customers have had something to say about the tiniest of wrinkles upon pick-up. We always tell them- give it a week, they should come out, if not come back. we've never had anyone come back... but the down side- most of the pics of my work are before the seats get a chance to puff up... very rarely will a customer come by just to thank ya! Quote:
Just one more little tip- if your foam is collapsed, before you re-tighten a new cover over it, try to steam the foam, it'll usually puff up a whole lot. if you have no access to a steamer a closed bathroom with the hot water in the shower usually does pretty good. or you can also do the sun trick- set in the sun for the hottest part of the day, it will puff up....but not as much as with the steam...
71 GMC lwb 56 Big window swb 93 GMC Sonoma (dd) radiused fiberglass fender project for 67-72 |
07-04-2009, 08:21 AM | #8 |
They call me the Breeze...
Nice job, the seat looks great!
Mike 69 K20 "Beer is proof God loves us and wants us to be happy"....Ben Franklin |
07-04-2009, 08:25 AM | #9 |
I am a Referee of life.
Seat looks great.Now a mod needs to put this in the FAQ's so we can keep "krue" busy with his index.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
07-04-2009, 08:36 AM | #10 |
Nice work.
Tony Johnson -- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer -- |
07-04-2009, 08:52 AM | #11 |
Confirmed Truckaholic
Very nice! That looks great.
1968 50th STEP SIDE SHORTY, 350/350, a/c, ps, p,b Daily Driver, 1970 Cst short fleet, all black, 350/350, 1970 2wd Blazer, 2wd, 6 cyl. 3 spd, original, now a 454, 350turbo, 3.73 posi, on the road 1971 2wd fleet shorty, 454, 700r4, 3.73 posi, SOLD to 67OLDSTYLE72 "My rig's a little old but that don't mean she's slow" - SAWYER BROWN's Six Days On The Road SEMPER FI "I use to be a lean mean fighting machine, but now I'm a huffin, puffin, over stuffin love muffin" |
07-04-2009, 09:26 AM | #12 |
Nothing to see here.....
faq thread candidate
Doug THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten". The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
07-04-2009, 11:23 AM | #13 |
landarts
Hey , thanks for all the good words. The original foam was in good shape. The bottom of the sitting cushion is what showed the most wear. The springs had worked the way up into the foam in a few places. That is where I insert scrap pieces of the Nufoam product. It did the job with ease and without distorting the seat.
07-04-2009, 11:53 AM | #14 | |
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
07-04-2009, 11:28 AM | #15 |
Looks great
70 SWB STEPSIDE 70 BLAZER 09 challenger |
07-04-2009, 12:12 PM | #16 |
wanna be 67
Where can you buy hog rings and pliers on the cheap?
07-04-2009, 12:46 PM | #17 | |
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
