Old 07-04-2009, 07:18 PM   #1
swtman
differential bearings
I would like to change my carrier bearings and pinion shaft bearings. If I use the same gears (they are in good shape) do I need to check backlash,pinion depth,gear pattern,etc or can I just change the bearings and be done with it? Any info would be greatly appreciated!
swtman is offline   Reply With Quote
Old 07-04-2009, 07:35 PM   #2
JimKshortstep4x4
Re: differential bearings
You will want to check everything.
Some times things work out but you want to make sure.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
