Old 07-06-2009, 10:59 AM   #1
71GMCNC
Question LMC Replacement Fuel Tank In-Cab
Need help, my fuel tank is toast. I have done the research and it would cost me about $120 to do it myself with new sender unit or around $200 for a brand new tank and sender unit from LMC. Is the replacement in cab tank from LMC worth it regarding quality, fit, and finish or should I just pony up remove the tank and do it myself?
What is wrong with my tank:
Major rust and varnish issues inside
Produces a rich rust color gas with chunks of rust and various gunk
'98 Chevy K1500 ext Cab Z71 4x4
196k miles and still going!
83' Chevy K10 Longbed 4x4. Dana 44 front and rear axles. Lift with 35's. Hopped up 350 V8, 4 speed manual w/granny. NP208 Transfer case SOLD!!!!
'71 GMC Shortbed 350 V8/Edelbrock performer intake and carb/Custom Dual Flowmaster 40 Exhaust
Currently in progress eventually 383 Stroker! SOLD!!!!
'67 Chevy C20 londbed Original 327 V8/4 Speed Custom Cherry bomb Exhaust
Inline to be next project sporitng primer grey SOLD!!!!!
71GMCNC is offline   Reply With Quote
Old 07-06-2009, 11:48 AM   #2
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Re: LMC Replacement Fuel Tank In-Cab
Can't tell you about LMC's tank quality but I can give you another reason to replace the tank. That is because the flange that snuggs the gas cap down is probably worn out. When that flange wares out the tank drips fuel when it is full and you are turning right. A new cap will fix it for a short time, but it will soon leak again, witch will cause you to think you have a bad gas cap, when in reality it is the flange of the gas filler neck. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 07-06-2009, 01:06 PM   #3
ZombieWeinerDog
ZombieWeinerDog's Avatar
i got the lmc tank, my old one had a full tank of gas for 20 years. it rotted everything, the lmc bolted right in no problem. i used the original gasket for the filler neck.
1972 longbed- 454
1967 shortbed- 355
ZombieWeinerDog is offline   Reply With Quote
Old 07-06-2009, 10:58 PM   #4
finadic
I just pulled mine out its in great shape no rust at all its in great shape sending unit works as well if you want it its yours just pay shipping from dallas georgia (Just west of atlanta). replaced with tank from summit.
finadic is offline   Reply With Quote
Old 07-09-2009, 08:09 AM   #5
bigsnookmaster
bigsnookmaster's Avatar
I would take this gentlemans offer,it's cheap,GM,and a bolt in with no problems.Very nice offer!
bigsnookmaster is offline   Reply With Quote
Old 07-07-2009, 08:54 AM   #6
peleni
peleni's Avatar
I replaced mine from LMC, had to do a little "tuning" with the filler neck but all in all it turned out nicely, I bought the new rubber for the neck but did not like the way it fit so went with the original.
peleni is offline   Reply With Quote
Old 07-07-2009, 11:01 AM   #7
71GMCNC
Ok put one on order w/ECC and a new sending unit and filler grommet. That should get my '71 GMC running by end of next week. I took a look at my '67 and will need to replace that tank as well but the '71 is the first priority.
Thanks all for the replies!
Old 07-07-2009, 04:26 PM   #8
Bob B.
There seems to be at least 2 manufacturers for stock in-cab fuel tanks. One type (which I bought from Goodmark) fit very well with a minor 'adjustment' of the filler neck. This tank had a corrugated filler next like the original, and was made in Canada. The other type was made in Taiwan, and was a disaster. The filler neck was not corrugated. It seemed that they didn't hold the halves flat when they welded it together, and the tank was warped better that 2 inches. No way could you get all the bolts in it. The flange at the top was too wide, and the tank would not fit under the upper inside cab corner on the left side. The filler neck was nowhere near the hole in the cab.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 07-07-2009, 09:03 PM   #9
austinstocker
austinstocker's Avatar
I just bought a blazer tank from LMC to mount under the bed of my 67 C10... The tank is definitely not factory quality. At this point, I am still going to mount it in my pickup. If you really can't stand something that isn't OEM quality, I would not go with the LMC Truck one.. Or from what Bob B. is saying... call LMC and find out where they are getting these tanks made.
austinstocker is offline   Reply With Quote
Old 07-09-2009, 08:40 AM   #10
71GMCNC
PM was sent. Waiting on reply for shipping to my zip. My 67's tank is worse off than my 71.
