Old 07-07-2009, 06:15 PM   #1
basemodel67
Factory Strippers Rule!
basemodel67's Avatar
Giant Brake kits?
Anyone have big brakes out there? I'm trying to find a 14" rotor setup or bigger -and beefy calipers to match- for 6-lug trucks.
basemodel67 is offline   Reply With Quote
Old 07-07-2009, 10:10 PM   #2
basemodel67
Re: Giant Brake kits?
Okay, how about any brake setups bigger than stock?
Old 07-07-2009, 10:17 PM   #3
PBFAB.COM
PBFAB.COM's Avatar
I offer a McGaughy's 13" kit. It very nice and affordable. Front and rear set-ups under $1500. If you're looking for 14" plus you may have to adapt a different suspension.
You can always update to C4 suspension via a Dropmember... I know there are some monster brake kits available for the 88-96 C4 components.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 07-08-2009, 08:33 PM   #4
Wild83C10
Wild83C10's Avatar
Take that one further and use the C4 DM and an adapter bracket to upgrade to a C5 brakes or even the huge C6 brakes. A set of $75 brackets will allow you to do this. Not even worth using the C4 brakes.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 07-08-2009, 01:18 AM   #5
Twisted Minis
Twisted Minis's Avatar
I can build a 14" brake setup, but it's not cheap. Once you go past 13 inches, rotors seem to get a lot more expensive. Also once you go to a 6-piston caliper, same deal. $$$. 4 piston calipers are pretty affordable though.
To go that big you are going to end up with something custom most likely, not an off the shelf kit. But it can be done. The McGaughy's kit would probably be a more economical choice.
If you can find it cheaper, I can fix it!
Twisted Minis is offline   Reply With Quote
Old 07-08-2009, 09:50 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Twisted Minis is correct. Big Brakes equal big bucks. Search Baer, Wilwood, SSBC for their kits and look at the prices. They don't make what your looking for, but it will give you an idea on cost.
Just for sake conversation, would it be practical to adapt a late model 6 lug to early A-arms?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-08-2009, 10:29 AM   #7
PBFAB.COM
PBFAB.COM's Avatar
The spindle geometry is where the issue lies. I haven't taken the time to sit down and compare the spindle diffreneces between the early and late models. It might be more practical than one would think, and then again, it might not be! The more aftermarket brake kits that become available for our trucks make it less and less beneficial IMO.
As mentioned, Big Brakes = Big Bucks... any way you go.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 07-08-2009, 12:26 PM   #8
basemodel67
I kinda agree with N2TRUX that if there was a way to be able to use the brake upgrade kits for newer trucks that would open up a world of upgrades. But I also understand that trying to inbreed different truck generations might lead to a pantload of new problems. I just don't want to cheese out on the stuff that is important to a truck build like suspension, drivetrain, and brakes and have to redo stuff because I went cheap.
Old 07-08-2009, 01:55 PM   #9
SCOTI
SCOTI's Avatar
Using later model stuff really doesn't get you anywhere. You still have to purchase the upgraded 'kits' to get the big brakes on late models & I've yet to see any that are 'cheap' and they're somewhat mass produced.
Why 6-lug? There are big-brake kits out there for 5-lug wheels.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 07-08-2009, 03:15 PM   #10
basemodel67
I know that I will be spending some big money for brakes anyways, there's no getting around it. As for 6-lug, I just think it looks beefier, although it somewhat limits wheel choices.
Old 07-08-2009, 07:32 PM   #11
Twisted Minis
I agree with Nate on the late modal deal. If the spindles differ too much in balljoint and tie rod placement, and incline, it could do more harm than good in the long run.
If someone goes through the process to get the first set prototyped, they could be put together as a kit after that and made accessible to everyone.
Old 07-09-2009, 12:23 PM   #12
LMDGUY
LMDGUY's Avatar
Baer brakes offers large brake kit, but not cheap. Call Bill K. at Baer is is really helpful.
1973 C10 "Chain Reaction"
Street Trucks cover Feb 2012
2013 Silverado
1964 Cadillac
LMDGUY is offline   Reply With Quote
