07-08-2009, 06:46 AM | #1 |
6 lug front disks
I currently have a ECE front disk conversion kit that is 5 lugs. what would it take to convert this to 6 lug. Is it as simple as swapping out the rotors?
07-08-2009, 07:07 AM | #2 |
sharp as a marble
Re: 6 lug front disks
I bought a set of spindles, and have a set of 5 lug rotors I bought from NAPA. I removed the outer wheel bearing races, and checked the numbers on them. I then called master power brakes, and asked the to do the same thing, and found it was as easy as swapping the rotors. thought this picture would show 6 lugs, but it does not.
07-08-2009, 07:15 AM | #3 |
how much did they run you?
i just found them for $89 each from ECE. |
07-08-2009, 07:20 AM | #4 |
I am wandering if there is a certain year 6 lug chevy rotor that will fit that i can get from any parts house.
07-08-2009, 07:52 AM | #5 |
Tot Roddin'
dznucks... I would definitely recommend ECE's 6-lug kit for your project. They offer some of the best products and customer service I've seen. You might be able to contact Stan/Mark at ECE to help you determine another make/model for the 6-lug rotor.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
07-08-2009, 08:06 AM | #6 |
Like i mentioned i already have the ECE 5 Lug disc kit installed on my truck. I am wanting to swap back to 6 lugs and all i need are the discs. I have numerous ECE products on my vehicle and they do have great quality, but they also mark up their prices pretty good too.
i am not looking to spend $89 per disc if i can go to napa and get the same thing for $50. |
07-08-2009, 10:40 AM | #7 | |
So to answer your question, I do not think you are going to get six lugs on your spindle w/out buying conversion rotors, if you find I am wrong please let the board know, alot of guys here are interested
1969 Short Stepside 1969 4 WD Suburban 1970 1 Ton Dually....Misfit oh, and a 2001 HD 2500, 8.1 Allison Shortbed 4 Door |
07-08-2009, 11:33 AM | #8 |
ok that answers my question then.
07-08-2009, 05:54 PM | #9 |
sharp as a marble
When I looked for my 6 luggers, I did not try what I did thru my local sources. I think you are going to a specialty house to get them. I think I paid about 90 per rotor and got them from MASTER POWER BRAKES. You might give BRAKE TECH SOLUTIONS a call, and ask for Pat. he is very helpful.
07-08-2009, 08:15 AM | #10 |
Tot Roddin'
Misread on my part.... but I did mention to contact Stan/Mark to see if they might be able to provide you with an alternative to the 6 lug disc they offer.
07-09-2009, 09:43 AM | #11 |
Keepin it old school
I talked to a guy at ECE he told me they never made a 6 lug rotor for these trucks and there isnt a off the shelf rotor you can use.
He also told me that the 6 lug rotors they sell are just stock 5 lug rotors that were drilled for 6 lug instead of 5. He said there is some difference in machining to the backside in order to drill them for 6 lug. You can use the rotor they carry on any stock spindle or drop spindle that works with stock disk brake parts.. Last edited by Bazooka; 07-09-2009 at 09:43 AM. |
07-09-2009, 06:39 AM | #12 |
Was a six lug disk not an option on our trucks? or is it the drop spindle that they wont fit on?
07-09-2009, 06:53 AM | #13 |
sharp as a marble
disc brakes came on 71 and up I think. That would make it 5 lug only?
