Old 07-09-2009, 02:35 AM   #1
xratt
xratt's Avatar
fuel gauge ohm.'s for a 1966 c10?
i was getting ready to buy a 0 - 90 ohm. sending unit to mount in my aftermarket bed mounted tank, to work with my stock fuel gauge in the dash of my 1966 C10. Then i ran across some info about 2 different ohm. ranges for stock gauges. I know the stock gauge works, turn key on and its says full, ground out sending unit wire and it says empty. Just dont want to buy the wrong sending unit. And tired of getting stuck on the side of the road with my little gas can.
thanks for your help
1966 C10, SB305, bagged.
1955 VW Buggy, 2.0L
1978 Honda CB550
http://67-72chevytrucks.com/vboard/s...9&goto=newpost
xratt is offline   Reply With Quote
Old 07-09-2009, 05:53 AM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: fuel gauge ohm.'s for a 1966 c10?
On my 64 I had to buy a sending unit for the remote big truck tank, the guy at the parts store told me there are positive ground units and negative ground units.
Old 07-09-2009, 08:05 AM   #3
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
xratt--yes, there can be two ohm ranges for our year (seems some '66's got the earlier, is it 0-30 (?) sender). If you have your old sender (assuming it was good) try checking it with an ohm meter. If I remember correctly (at my age, CRS is pretty active, so I can't promise), my '66 has the earlier version
fleetsidelarry is offline   Reply With Quote
Old 07-09-2009, 08:41 AM   #4
xratt
xratt's Avatar
thanks guys, i dont have the old tank or sender.
1955 VW Buggy, 2.0L
1978 Honda CB550
Old 07-09-2009, 08:15 PM   #5
TR65
TR65's Avatar
Xratt,
My 65 is for sure 0-30 ohm. I don't know when they changed to 0-90.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 07-09-2009, 08:21 PM   #6
TR65
TR65's Avatar
Xratt,
You could run 12 volts thru a 30 or 90 ohm resistor to the gage and see what it reads.
TR
1965 C10 SWB Fleet
Two owner
Old 11-24-2012, 07:55 PM   #7
jqbass66
i have a 1966 c 10 the gas gage go to full when you turn on the key.it has a 1964 mustang tank one wire on the send unit and have any idea
jqbass66 is offline   Reply With Quote
Old 11-25-2012, 03:55 AM   #8
Z POPPY
Jqbass66,
75-10 Ohms (Ford Type '86 and earlier)
16-158 Ohms (Ford Type '87 and later)
240-33 Ohms (Standard Aftermarket)
Good luck zpoppy
Z POPPY is offline   Reply With Quote
Old 11-25-2012, 03:56 AM   #9
Z POPPY
Jqbass66,
The Ford sender is not compatible with the trucks guage
Good luck zpoppy
Old 11-25-2012, 08:24 AM   #10
jqbass66
thanks for the help, is there anyway i can keep use that gas tank and have some kind of guage
Old 11-25-2012, 08:55 PM   #11
luvbowties
luvbowties's Avatar
Thumbs up Re: fuel gauge ohm.'s for a 1966 c10?
I have researched this issue thoroughly. Thru 1966, the pickups' factory fuel gauges used the 0-to-30 ohm sending unit, definitely. The GM CARS did not correspond with GM PICKUP year-changes; it seems this is where the mix-up came from concerning our pickups.
I've read where one (I don't recall any more, but there may have been.) person had what he thought was a factory sender from a 1966 C10 that had 90 ohms stamped on sender housing; but when he checked it with ohmmeter, it registered 30 ohms at max and near zero ohms at min, when on the float's other extreme.
HTH,
sam
**Someone's lucky day MAY be here at this soon-to-expire(like tonight?) ad: THE cheapest sending unit I've seen!!!
>> http://www.brotherstrucks.com/prodin...number=GTS6066 <<. And, no, I am not affiliated at all with this company; but I have never learned to pass up the chance to read auto-related ads!**
luvbowties is offline   Reply With Quote
Old 11-25-2012, 09:29 PM   #12
jqbass66
thanks
Old 11-25-2012, 10:56 PM   #13
hotrodder
I have a 63 Chev. that I have installed a set of Dolphin guages in. I have the tank still mounted inside the cab with the stock sending unit. The sending unit sits at a angle on top of the tank and then makes about a 45 degree bend after going down into the tank, the stock sending unit will not work with the guage so my question is has anyone modified the aftermarket sending unit to fit the top of the tank?
hotrodder is offline   Reply With Quote
Old 11-25-2012, 11:12 PM   #14
Mack B
Mack B's Avatar
I did just this, well took the old sender off the tube and welded the new. Sender to it, I got more pics of the process, pm me if you want them
Mack B is offline   Reply With Quote
Old 11-25-2012, 11:57 PM   #15
luvbowties
luvbowties's Avatar
This may help some of us gain confidence in which info is correct:
FOR STOCK FACTORY GAUGES: I guess we all are familiar with the name of Eckler's for parts--hence we maybe trust them. Look at this link & see for sure that our trucks from 60-66 all used 0-30 ohm sending units. Did not go to 0-90 ohms 'til 1967 on the trucks, even tho' GM cars changed earlier.
>> http://www.ecklerstrucks.com/chevy-t...1960-1966.html << Look up Part #: 129006 on Eckler's site.
Here's another supplier, Car Parts Discount, who shows specifically a 1965 GMC as having 0-27 ohm senders--I guess GMC was a tad more accurate & got it down to the "fine print", being more exact: their gauges prolly did not read beyond "F" when filled like our cheaper Chevies. Naturally, in the grand scheme, 0-27 is practically the same to such a circuit as 0-30 would be.
.....for GMC 1000-series (read their 0-27 ohm spec in description)
>> http://www.carpartsdiscount.com/auto...html?3593=2627 <<
...for GMC 1500-series: (read their 0-27 ohm spec in description)
Hope some of this helps,
sam
Old 04-15-2013, 08:16 PM   #16
cortcomp
cortcomp's Avatar
my mid year 66 was 0-30.
Project "i'm just going to clean up the interior and the engine bay":
http://67-72chevytrucks.com/vboard/s...d.php?t=550931
cortcomp is offline   Reply With Quote
