Old 01-06-2003, 06:25 PM   #1
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
Pass exhaust throgh frame???
ok, wondering about passin exhaust through the frame kinda like below, wondering what reinforcing to do? I fixured bx in around it, put pipein for the exhause to go through, and maybe some gussets, wondering in the if the bars running to the trailing arm crossmember are to supportit more? looks like te frame is boxed a lot too. any Ideas on strength for me?
thanks
Bryce
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 01-06-2003, 06:32 PM   #2
1971Stepside
Almost Satisfied
1971Stepside's Avatar
I saw that on that particular truck and liked it, but that was a lot of work. I believe the easiest way is to cut holes in your frame crossmembers and feed it within your rails. You can see in mine I used two 4" pieces of steel pipe that was cut 1/2" thick. We then cut out the crossmember and welded them in. Early Classics has more info on how they did this and Slammed67 did this to his truck.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 01-06-2003, 06:32 PM   #3
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
You can do it like that if you box the frame to reinforce it, or you could notch the frame just like a c-notch and enforce that. Same but different. LOL
01 Tahoe 22's 2/4 drop and tv's
68 chevy money pit
51 chevy belair
95 Honda 900RR
05 GMC Siearra (company truck)
NSANE68!!! is offline   Reply With Quote
Old 01-06-2003, 06:45 PM   #4
chevy2racr
chevy2racr's Avatar
Jason did too huh step? I was thinkin of exiting outthe sides infront of tires andthought I'd go outinstead, thanks for that idea NSANE didn't even think of notching
71 C10 with 454
09 Malibu
Marshalltown, Iowa
Old 01-06-2003, 07:33 PM   #5
Tynee
I miss this truck.
Tynee's Avatar
Out of curiosity, where's the benefit?
'07 GMC Acadia SLT. Sweet ride.
'08 Crew Cab Z-71 short bed. Really like this truck A LOT.
Tynee is offline   Reply With Quote
Old 01-06-2003, 09:04 PM   #6
chevy2racr
chevy2racr's Avatar
its not hanging below the frame
71 C10 with 454
09 Malibu
Marshalltown, Iowa
Old 01-06-2003, 09:22 PM   #7
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
Way too much trouble for exhaust.
Ben
67Fleetsidedream is offline   Reply With Quote
Old 01-06-2003, 09:47 PM   #8
67cst
i love summertime
67cst's Avatar
i agree, if i had a truck like slammed or 71 i would b/c it rides so low, like slammed witht he air bags, but if it was my truck (daily driver) i dont think it is worth the bother
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 01-06-2003, 09:49 PM   #9
crazy longhorn
Fabricate till you "puke"
Yup, those lowered trucks can cause a guy a lot of work! I have notched my trans crossmember, & built a crossmember for the center carrier(also notched). the exhaust is below the rails, but not more that 2". It works out good with a 3/5 drop & could go a little more without problems. The bodydrop was a chunk of work, but it gets the truck a little lower, & keeps the suspension pcs off the pavement.......it might be worth a thought
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-06-2003, 09:54 PM   #10
chevy2racr
chevy2racr's Avatar
I wouln't mind more info on a body drop, I don't know anythign about them so I haven't thought of them.. pics and discriptions woud help..
71 C10 with 454
09 Malibu
Marshalltown, Iowa
Old 01-06-2003, 10:10 PM   #11
crazy longhorn
mine was a very minor drop @ 1 1/2".....alot of guys go about 3". The frame horns were cut off ahead of the steer box, dropped & welded back on and boxed. Then the cab mount brackets were removed from the frame & dropped 1 1/2". the cab had a strip cut out from the toe boards to under the seat area(for the rails to stick up through), & a 16 guage 3 sided box was welded back in for clearance. a little padding under the carpet will cover the step in the floor. If you go much more than that 1 1/2", you would be better off cutting the complete center out of the floor & raising tunnel & all. On the box, I cut the lip of the box sides 1 1/2" up, & welded it back on. then finally out back, I used dropdown brackets to get the bumper at the proper height. I dont have any pics of the job, but i think there are a couple guys on the board that do. good luck....crazyL
Old 01-06-2003, 10:24 PM   #12
Low67C10
I did this just last week, but I went throuh the frame rail right behind of the trans crossmember . I bought some 4" .125 wall tubing, cut it at 45 degrees and made some boxing plates out of 1/8" steel plate. I made sure to make the boxing plates long enough to cover the hole in the frame and the boxing plate since the tube passes through the frame at a 45 so the holes are staggered. All together it was really easy but I welded the tubes to the boxing plates first and Id recommend welding it all togther at the same time. Also had to tweak some lines and remove the tailight wiring harness while I cut and welded. Its looks awesome and on a low truck is the way to go.
No, Its not a 454
Low67C10 is offline   Reply With Quote
