Old 07-12-2009, 11:57 PM   #1
Griz1055
Front Steering Knuckle Leaking Grease;LMC Doesn't Show Part?
Who has a seal for the ball or steering knuckle right next to the wheel? It is leaking grease which drips on my tire which then throws it everywhere. I can't find it in my LMC catalog or my Classic Truck Parts Cat. Any suggestions on who might have it? (69 3/4 4x4)
Thanks,
Brent
Griz1055 is offline   Reply With Quote
Old 07-13-2009, 08:52 AM   #2
nightmare
nightmare's Avatar
Re: Front Steering Knuckle Leaking Grease;LMC Doesn't Show Part?
i've only seen those with new ball joints. you may be able to find those at a local parts house, maybe in the Help! section or so
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is online now   Reply With Quote
Old 07-13-2009, 10:47 AM   #3
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Talking Re: Front Steering Knuckle Leaking Grease;LMC Doesn't Show Part?
I think he is referring to the closed knuckle on the axle. maybe these guys can help www.bjsoffroad.com click on axle parts then closed knuckle front ends.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 07-13-2009, 01:04 PM   #4
jerry moss
Born Psycho
jerry moss's Avatar
sounds like a good time to swap that closed knuckle axle out for a disc brake diff.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 07-13-2009, 08:27 PM   #5
Griz1055
Thanks, Black and Blue, that was it! Ahh, so much to learn...
Where would I get the disc conversion? (and an NV4500 and a Vortec and...)
Old 07-13-2009, 09:09 PM   #6
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Any front axle from 71-87.
68SWB4x4 is offline   Reply With Quote
Old 07-13-2009, 09:27 PM   #7
1969K10
1969K10's Avatar
Thanks,
Brent
are you looking for the felt gaskets that go on the inside? I have a spare set, that didn't mean to order, couple years old at this point, but still good.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 07-14-2009, 12:10 PM   #8
Griz1055
I thought it looked like a narrow rubber seal on the outside, but I may need the felt as well. I will pull it and let you know.
Thanks for all the help, guys! This forum is amazingly helpful!
