Old 07-19-2009, 07:30 AM   #1
Gene
Gene's Avatar
How do you guys set your cabs back on???
Ok, I dismantled my truck about 4 months ago to start the process of turning it into a 4wd, and now I have located a frame. After I get it sandblasted and painted HOW IN THE HECK AM I GOING TO GET THE CAB BACK ON????? I used my bro-in-law's deisel forklift to remove the cab, but now it's down with transmission problems. How is the most common way of getting these suckers back on the frames?
Gene is offline   Reply With Quote
Old 07-19-2009, 07:42 AM   #2
Re: How do you guys set your cabs back on???
I use a cherry picker. Supposedly 4 healthy guys can do it. I just never had four healthy guys to do it for me when I needed it done.
Old 07-19-2009, 08:02 AM   #3
jackyl9999
jackyl9999's Avatar
I lifted mine using the rafters in my shop. Then just rolled the frame under it. Think I tied the straps to the door strikers and the hinges. Not real sure about that.
You will need a few people on hand, just to man handle it. Problem with lifting it by hand is 1. there is no real good place to hold it. 2. you have to pick up and put it down several times if you have issues with the cab mounts.
Be careful.
1970 Gmc Grande Sierra Swb 2wd LSX (LQ4/4L80e)
1990 K1500 Daily
jackyl9999 is offline   Reply With Quote
Old 07-19-2009, 08:14 AM   #4
Sammy
I have reinforced the rafters just to feel safer with a couple 8' 2 X 4's then a strap thru the open windows around the cab roof. Alignment two guys can manage this way. Once you get the cab loosely mounted install the front fenders to insure you don't have the cab crooked or too far forward etc. Then snug the cab mount bolts. 1/2 " on one side throws stuff off. Noticeable with the bumper alignment.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 07-19-2009, 10:03 AM   #5
Shyguy
Junior Member
Shyguy's Avatar
Are you putting the cab back on the frame you took it off of, if so you will not have any problem with fitment of the front clip to the cab.
If you are putting the cab on a 4x4 frame the rear cab mounts are thicker than those of the non 4x4s.
We always use the cherry picker method to remove and replace cabs, we got the idea from someone one on here. We have done 4 cabs so far and the method works great. On all 4 occasions we had the doors on the cabs.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 07-19-2009, 10:18 AM   #6
68_Bowtie
68_Bowtie's Avatar
4 of us manhandled mine on. It was bare except the windshield and back glass.
68' SWB 355 CID since 1987
89' S15 4WD 4.3
08' VTX 1300R
08' Chevrolet HHR (Wife's ride)
"That man right there is the best sprint car driver in the whole ---damned country!" 1974- Indianapolis- AJ Foyt pointing out Jan Opperman in the garage.
68_Bowtie is offline   Reply With Quote
Old 07-19-2009, 11:30 AM   #7
Gene
Gene's Avatar
Danny
Putting it on another 4x4 frame, I will order mounts for a 4wd. And I will use the cherry picker method, I need to pick one up anyways! Thanks for the suggestions guys...
Old 07-19-2009, 12:42 PM   #8
eagleuh1
eagleuh1's Avatar
This was on another post here earlier.
http://www.lewisfabricationdesign.com/products.aspx
eagleuh1 is offline   Reply With Quote
Old 07-19-2009, 05:25 PM   #9
hugger6933
Two post lift ,here. It works great for cabs, beds, changing suburban and tahoe bodies. I also use it to lift and hold something while mounting it on the rotissere. Jim
hugger6933 is offline   Reply With Quote
Old 07-19-2009, 07:02 PM   #10
JimKshortstep4x4
Here is a picture of my son's Burb body that we were setting back on the frame. We use two 1/2 ton chain falls hooked to reenforced rafters for lifting the bodies. One person can work the chain falls but with two it is a lot easier to align the frame to the body. System works for any car or truck body.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 07-19-2009, 10:02 PM   #11
lilred67
lilred67's Avatar
i used the crane on one of my work trucks....
lilred67 is offline   Reply With Quote
Old 07-20-2009, 06:37 AM   #12
hgs_notes
GEARHEAD
hgs_notes's Avatar
I used an engine hoist/cherry picker with some pieces of angle iron bolted to the seat mount holes in the floor. I had my load leveler on the hoist also. The only problem was having to have a second person to help steady it while moving it around.
hgs_notes is offline   Reply With Quote
Old 07-20-2009, 10:19 AM   #13
1956cameo
1956cameo's Avatar
Sorry to go off topic but, Jimkshortstep4x4 you have to post some build pics of that burb over in the suburban forum for the rest of us. It looks like it is going to be gorgeous.
1956cameo is offline   Reply With Quote
Old 07-20-2009, 10:28 AM   #14
TEXAS 68
Vortec in the works
TEXAS 68's Avatar
Engine hoist and a 4x4 worked for me. Especally if you doing it yourself with no help.
68? It's all figured out untill you get it apart.
Is it Sunday yet???
68 Project
68 SWB frame off/98 Vortec with stock FI/power everything.
95 ECLB 2500 with 346,000 on the clock(the original HD)
99 Lesabre-wifes ride
08 Crew Cab LTZ-All Mine
89 SWB 5/7 drop-Son's first ride.
TEXAS 68 is offline   Reply With Quote
Old 07-20-2009, 03:30 PM   #15
hicktownhotrodder
Rollin Coal
hicktownhotrodder's Avatar
Pallet forks on a skidloader. works real slick but have done the straps around the roof. now i was told that you should NEVER put the strap through the windows of the doors. am i right or just nuts?
I have three letters to all these import guys:
God-Made-Chevy
04 GMC Sierra 2500HD Duramax
1972 Chevrolet C-30 Dually Pickup stock? 350 SM465 four speed
1977 GMC K-35, TH-400, 4X4 450 horse 454(dad's)
1993 Dodge cummins 5-speed DEAD!!
hicktownhotrodder is offline   Reply With Quote
Old 07-20-2009, 03:47 PM   #16
arm51
beer me
arm51's Avatar
when i get to that point in my build i am going to use my backhoe i think that will get r done if you have a backhoe or a friend closeby with one
1969 c10 currently on hold because of a darn f**d
1986 f150
1986 silverado-my dads truck that i'm fixin up
ill keep my freedom my guns my money my religion and you can keep your CHANGE-hank williams jr
arm51 is offline   Reply With Quote
Old 07-20-2009, 03:45 PM   #17
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Engine hoist here too.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 08-17-2009, 08:11 AM   #18
Chada
Four of us lifted mine off and on. Really very easy took two minutes. Had the front and back glass but no doors.
Chada is offline   Reply With Quote
Old 08-17-2009, 08:24 AM   #19
Chada
Yes we had to replace the cab supports and reweld where the floor meets the rockers and we just turned it so we stood right in front of the cab floor which made it much easier.
Old 08-17-2009, 08:56 AM   #20
JimKshortstep4x4
Here is a pic of a cab setting on a trailer. A skid is used under the firewall to get the cab up in the air and straps are used to make sure the cab does not tip either way when working on it.
This makes repairs on the underside very easy.
Jim
Old 08-17-2009, 10:48 AM   #21
70c10-08
70c10-08's Avatar
It took me and a friend to get the cab off of my c/10 and thats prolly how ill get it back on too but thats with nothing in or on the cab
70c10-08 is offline   Reply With Quote
Old 08-17-2009, 10:52 AM   #22
Ackattack
Ackattack's Avatar
I'm manhandled them and used a cherry picker.
Much easier with a cherry picker.
Ackattack is offline   Reply With Quote
