Old 07-21-2009, 08:41 AM   #1
69ShortStep
69ShortStep's Avatar
I6 3spd Transmission Mount
Hello,
I have been investigating a vibration under cab when exceeding 50mph. Have replaced wheels/tires and it made no difference. Took a look under the truck and found that the transmission did not have a crossmember/mount. Is that normal for an I6/3spd?
Thanks in advance.
69ShortStep is offline   Reply With Quote
Old 07-21-2009, 08:50 AM   #2
dznucks
dznucks's Avatar
Re: I6 3spd Transmission Mount
yes. mine is the same way. seems odd that the tranny is cantilevered off the back of the motor. i was thinking of fabing one myself. Fatigue wise, that cant be good for the motor mounts or bellhousing/tranny and bellhousing/engine interface.
dznucks is offline   Reply With Quote
Old 07-21-2009, 09:30 AM   #3
sjarrett71
sjarrett71's Avatar
I have a 6cylinder 3 speed combo and I have a crossmember although it's almost rusted in half!
-Scott-
sjarrett71 is offline   Reply With Quote
Old 07-21-2009, 07:52 PM   #4
69ShortStep
Thanks for the replies.
Does anyone have a picture of a stock or fabricated crossmember/mount they have made?
If anyone has recently purchased one, please let me know what you got.
Old 07-21-2009, 07:58 PM   #5
bhoeger70
bhoeger70's Avatar
the 6cyls manual trans trucks that I have had and have all had the two front motor mounts and the rear mounts were on the bellhousing. The trans is just left hanging there. The vibration you might what to check could be the driveshaft (u-joints or hanger bearing).
"Beer is proof that God loves us and wants us to be happy" Ben Franklin
67 Chevy 1/2 lwb, 67 GMC 1/2 lwb (parts)
bhoeger70 is offline   Reply With Quote
Old 07-22-2009, 02:54 PM   #6
68gmsee
Active Member
68gmsee's Avatar
Originally Posted by bhoeger70 View Post
.......... The vibration you might what to check could be the driveshaft.............
I agree.
I forgot to mention that I have a slight vibration on mine at about the same speed. I know it's an out of balance driveshaft since I've had tires rebalanced, replaced u-joints, yoke asm, driveshaft bearings and checked mounts, etc.
The drive-line shop said about $50 to balance it a few years ago. I just haven't gotten around to doing it.
68gmsee is offline   Reply With Quote
Old 07-22-2009, 03:03 PM   #7
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Originally Posted by 68gmsee View Post
I agree.
Try spinning the the rear u-joint 180* in the rear yoke. It worked for me after i had mine out and put it back in it vibrated so I figured i didn't put the u-joint back in the same way it came out.
LOW DOUGH is offline   Reply With Quote
Old 07-21-2009, 11:26 PM   #8
nicks05z71
nicks05z71's Avatar
do you have a 2 peice drive shaft? If so you might look at your carrier bearing.
I have a 3 speed w/overdrive (longer), with only the crossmember on the bell housing, with no issues.
You might also want to check to make sure all your bell housing bolts are tight and rivets on the cossmember are not broke.
nicks05z71 is offline   Reply With Quote
Old 07-22-2009, 08:01 AM   #9
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
No need in second guessing GMs engineering. No matter that it looks crazy, the trans hanging off there is sturdy enough that you don't need to supplement it with other mounts. Those engineers were pretty smart.
You think it looks weird having a 3 speed hanging in mid air, you should see a granny 4 speed truck. That's a lot of iron.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 07-22-2009, 09:33 AM   #10
68gmsee
Active Member
68gmsee's Avatar
If you use your truck like a work truck and/or off-road, a crossmember on the back of the 6 cylinder 3 speed may cause your bellhousing or transmission to crack. This is because of the length of the engine to the rear of the transmission and the twisting or flexing of the drive train or frame when going over uneven terrain. The rigidity of the three mounting areas prevent enough flexing.
Old 07-22-2009, 11:37 AM   #11
69ShortStep
My truck has a 1 piece driveshaft. U-joints seem tight ( No clunking when shifting into reverse ). I will check that the bell housing bolts are tight and rivets on the crossmember are not broke.
Thanks for the info/advise.
Old 07-22-2009, 02:16 PM   #12
Shaky
Six in a row makes it go...
Shaky's Avatar
Another thing to check is your harmonic balancer. Mine slipped the outer ring and it had a vibration at certain rpm. Of course, it was impossible to get the timing right too.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 07-22-2009, 03:05 PM   #13
Tx Firefighter
I'm cheap. I always put a big hose clamp around the driveshaft and rotate it a bit at a time until the vibration goes away. It takes a few test drives and crawling under the truck to get it clocked right, but free is free.
Old 07-22-2009, 04:45 PM   #14
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
^^^^ yep, you could do that too. Fine tuneing LOL
Old 07-22-2009, 05:10 PM   #15
68gmsee
Active Member
68gmsee's Avatar
Low Dough, Tx Firefighter... I haven't tried the 180 turn on my 68 but I did use the large hose clamp on my 69. Worked pretty good and might be worth a try.
Old 07-22-2009, 09:03 PM   #16
Legolas894
Chemist under the hood...
Legolas894's Avatar
I'm not sure I'd notice the vibrations in my truck with the mirrors whistling, 4-speed howling, wind coming in the cowl, back bed clunking, metal dash and doors etc.
I don't think these trucks were meant to be quiet.
Current fleet:
2013 GMC Sierra, 5.3L, 4x4
1988 GMC Sierra, 305, Auto
1984 Jeep Grand Wagoneer, 360 V8
1997 VW Cabrio, 2.0L
2017 Toyota Rav4, 2.5L
Stuff I wish I still had:
2013 Toyota Matrix [RIP]
1967 GMC 910 Fleetside, 283 V8 [1st Love-SOLD]
1987 Jeep Cherokee Laredo 4X4, 4.0 I-6 [SOLD}
1994 Chevrolet Caprice Classic, 5.7LV8 [SOLD]
1995 Chevrolet Astro AWD, 4.3L V6 (RIP)
1998 Chevrolet Suburban 4x4, 5.7L V8 [SOLD]
Legolas894 is offline   Reply With Quote
Old 07-23-2009, 12:52 PM   #17
69ShortStep
Thanks for all of the great suggestions.
I am definately going to try spinning the the rear u-joint 180* in the rear yoke and the large hose clamp if necessary.
Will report back with results.
Old 07-23-2009, 01:17 PM   #18
dznucks
dznucks's Avatar
as far as the clocking u joints go. you want to make sure that the grease fittings are clocked 180* out. if you have both grease fittings on the same side this will cause a vibration.
