Some big questions.....
HI gang, I am new to this site and have cruzed through some of the posts, I must say all of you are going to be a very helpful bunch! So shall we begin? I just bough a 68 GMC Short fleet 4x4. It still has drums on the front. I looked in the LMC bible and did not see a disk conversion for 4X4's. Does this mean that it cant be done? do i have to get newer axels? Also I want to upgrade to power steering, I read on here that a 67 3/4 ton has a tighter lock to lock wheel turn. I have Most of my 67 3/4 from when I was a kid, ( first truck, and yep, I rolled it, sad sad day) the 67 was power steering, will this fit in my 1/2 ton?. I am sure I will have a few more questions as the project progresses. ![]() James, happy to be in a real mans truck again lol Gmc2 |
Dave's not here, man
Re: Some big questions.....
Welcome to the board! I wish I could help you more but I don't know much about the 4 wheel drives. I am certain that someone will chime in soon with some answers for you.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
Roadtrip!
![]() Join Date: Feb 2003
It will be easier to swap the whole front end. I "think" 71 until well into the late 70s is a direct bolt in for you. I can't help much on the steering. I would think a set up from an early 70s 4x4 should work.
An original 68 gmc short, fleet 4x4 would be a fairly uncommon truck. Any pics or more info? Welcome, Eric
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Big Red - Now its a SWB!
welcome to the board, sounds like it will make for a nice truck
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
anything is possible with time and money
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
hey if you are interested I could get some measurements and/or pics of a 75ish blazer axle to see if the later 1/2 4wd parts would work, I have one sitting out by my gmc that I could check. If these are a bolt up like was stated earlier this would be easy to find in any junk yard. You may be able to use the axle off of a later truck but you cannot use the pump because 1968 was the last year that they had the short water pump so after that all the bracketry changed. I would think that you could pull that off of your 68 though. Good luck and let me know if you would like pics or measurements, the only thing is that I won't be home until friday.
thank you Jacfouteen, that would be great to see some pics and some messurments, I was talking to someone today about putting in a newer axel and they were not sure that the hangers and width would match up. I don't want to hack too much up, if a 68 short fleet 4x4 is as rare as i think it is, i think that i may want to make it possible to go back to stock. I am going to post some pics, just have to figure out how first lol.
#8 | |
i will post some pics under the title 68 GMC short fleet 4x4
Alright I took some measurements of the blazer in my field today. Its not in the best spot to take pictures, lots of stickers and a fence up against the side but I did what I could
![]() Here is a pic of the blazer so you could see what I was measuring in: ![]() And here is a pic of the gearbox setup (what I thought was most important and the only clear shot I could get): ![]() Hope this helps, best of luck!
thanks Jacfourteen! that will give me lots to work with, i will let you know if I have any more questions. Thanks again for all your help
[B][/B ![]() James 68 GMC SHORT FLEET 4x4 83 Dodge short fleet 2x4 2000 Civic SI ![]() |
