Old 07-22-2009, 04:38 PM   #1
Gene
Gene's Avatar
Sandblasting the frame
How far do you guys break your chassis down when prepping for blasting? I removed the brake lines and fuel lines, any extra bolts and shocks. Have any of you had your suspension blasted as a whole intact on the frame? Whats the best way to go about this? I've never done a frame off and am full of questions.
Gene is offline   Reply With Quote
Old 07-22-2009, 04:50 PM   #2
d10s69c10
Built 4 Speed
d10s69c10's Avatar
Re: Sandblasting the frame
you best bet would be to sandblast piece by piece wash down with acetone and prime. basicly thats the best way to do it if surface rust is any concern.
the whole rolling chassis could be done but might turn into a bear if you dont have a mega blaster a indoor shop and alot of time back to back.
1969 C/10 Short Box:
496/T-56 in worx.
"To Be Old And Wise, First You Must Be Young And Stupid"
d10s69c10 is offline   Reply With Quote
Old 07-22-2009, 04:59 PM   #3
Rack Man
If your doing a complete frame off...take it all the way down....You need to get all the dirt, grime & rust out of all those hidden areas....Also, no matter how careful you are that sand can easliy get into every crevise of an axle....
Here's post sandblasting - after powdercoat:
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288
Rack Man is offline   Reply With Quote
Old 07-22-2009, 05:10 PM   #4
d10s69c10
Built 4 Speed
d10s69c10's Avatar
^ show off!
looks good
496/T-56 in worx.
Old 07-23-2009, 12:38 AM   #5
Captainfab
60-66 Nut
I would say it depends on just how nice and detailed you want it to be. I usually remove/disassemble everything that doesn't require a torch or plasma cutter Just remember every place where one part is attached to another, there is going to be dirt,grease and rust in that joint. It's easy to get carried away......
Old 07-23-2009, 10:51 AM   #6
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
we pulled the motor crossmember out pre powder coat and blasting, but my rear frame was rusted, so we disassembled some of the rear shackle brackets as well and blasted behind them and decided to patch the frame where it was ate away. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 07-23-2009, 04:54 PM   #7
Gene
Gene's Avatar
My wife hates you by the way Trevor, your truck is the reason I decided to turn mine into a 4wd Back on topic, I was wondering about the motor crossmember, I think i'll pull it also, and maybe the transfer case mount? I was considering taking the rolling chassis to sandblasting, but since i'm replacing all the leafs when I raise it, I think i'll just take it dissasembled. The differentials are pretty rusty also.
Old 07-24-2009, 12:30 AM   #8
71blksuper4x4
SWB 4x4 Collector
Boy, I feel loved We left the transfer case crossmember in the frame to add rigidity to the frame in the center, but we took out the actual transfer case mounts to sandblast seperate. Trevor
TREVOR
Old 07-24-2009, 04:01 PM   #9
Gene
Gene's Avatar
Well, I removed the motor crossmember and it was just as rusted underneath as the rest of the frame (surface rust) So I think i'll remove the transfer case crossmember also at the blast shop. Got any updated pics of your truck Trevor? I am wondering where I am going to get pre-bent brake and fuel lines since LMC doesn't carry them?
Old 07-24-2009, 10:44 PM   #10
Captainfab
60-66 Nut
Have you checked with Inline Tube? You could also just get straight lengths of line, a tube bender, and a flaring tool at yout local auto parts store and make them up yourself.
