Old 07-25-2009, 07:36 AM   #1
hd74
power assit to power steering
1963 gmc suburan. i have swapped over to disc brakes all ready i used tie rod adapters annd 6 lug calibers and now i want to chang using a power steering box insteed of my now powere assit steering. what all do i need to change out? draglink? or such thanks
hd74 is offline   Reply With Quote
Old 07-25-2009, 11:19 PM   #2
Captainfab
60-66 Nut
Re: power assit to power steering
You'll need to change the draglink for sure. I'm not sure how your 'tie rod adapters' will fit in there since I don't use them. It will most likely depend on which draglink you switch to. Then of course you will need the power steering box adapter plate and a steering box. If you get a power steering box that is a '69-'79 then it will have the SAE fittings like your current pump does.
Old 07-26-2009, 05:32 PM   #3
hd74
which drag links will work? pro`s and con`s thanks
Old 07-26-2009, 11:35 PM   #4
Captainfab
60-66 Nut
Well considering you've already got the tie rod adapters, you could just switch to a '63-66 drag link for manual steering. If you were to switch to a later model draglink such as a '73-'87 (what I use) then you would have to upgrade to the corresponding inner tie rods. In which case you wouldn't need those tie rod adapters.
Old 08-21-2009, 12:32 AM   #5
70 Suburban
Rods
i would be intrested in the parts you take off...
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
Old 08-23-2009, 04:02 PM   #6
hd74
let me know what you need.i took off everything off today. i have gone to the never style. i suggest you do the same
Old 08-23-2009, 04:22 PM   #7
70 Suburban
Rods
i need it all. sucks but mine was gutted as far as p/s. I had a 65 when i was 15 and drove it im good with my popeye arms... but I want the power assist becaus it came with it and right now its all stock. I ahve (need the parts to it) p/s p/brakes,, a/c. truck.
if you need anything in trade leme know.
