going to buy a set of American Racing Torque Thrust II's, and going to run 275/60/R15 BFG Comp T/A's, which rim width would look better??? 15x8 or 15x10??? will a 15x10 clear on the front with that big of tire???
this on a '72 1/2 ton 2wd.
'72 C-10 Cheyenne Super, 402/TH400, Bucket Seats, tilt, tach, AM/FM & shoulder harnesses and a ground up restoration |
Used to have a truck
I used the same tire on a 69 camaro (4.30 gears in a narrowed nine inch) with 15x8's and got the impression that 15X10's would have been too wide. Its got 305/50 Euro TA's on it now with 15X10 welds and theyre sized pretty good for the tire.
No truck :-( |
its all about the +6 inches
I have 15 X 9 1/2 on the GMC...275/60's fit on there perfect. nice flat foot print. A good tire dealer should be able to tell you the facts.
------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite. E-mail longhornmail@yahoo.com My name is Andy...not Randy...I'm in Ohio...Not Illinois...close enough? Columbus Ohio |
I have 275/60/15s on 8" ralleys,& they print ok. I think they could be on a little wider wheel(8 1/2-9" should be optimum,from the charts I have seen),but I also feel that 10" is a little wide for that size tire......69
http://community.webshots.com/user/hotrodhorn |
I've always been partial to the 15x15s on my 69.
------------------ 69 Chevy ProStreet, Low and wild. Check it out http://y42.photos.yahoo.com/bluzman2004
69 Chevy ProStreet, Low and wild. 78 Corvette rturnpaugh@compcams.com |
I'm running 15x8 (205/60R15)on the front and 15x10 (295/50R15) on the rear.
I just liked the look. doesnt make the tires last long not being able to rotate.. but hey, they have lasted me 4 years already. ------------------ Pictures and more... piston@zkast.com '71 LWB 350/350T, PS/PB Special options? Yes, RUST... Need some? ------------------------------------------ Webmaster/Team owner www.zkast.com Garrett - Olathe, Kansas |
rotate...bbah! I find that just gives me 4 bald tires instead of two!
![]() Join Date: Dec 1999
I have 15x10's with that tire on the back and they fit fine. Me personally would not run 10's all the way around on a 2-wheel drive. If I was going the same size all the way around it would be 8's.
------------------ 67 GMC Stepside(UNDER CONSTRUCTION) 67 GMC Custom 67 Chevy C-30 |
I have 15X10 on the front of my 72' and I have no clearance problems.
------------------ 72' Cheyenne, 2-1/2 exhaust, 350 with 268 comp cam,
72' Cheyenne, 2-1/2 exhaust, 350 with 268 comp cam, |
