07-27-2009, 04:44 PM | #1 |
You Boys notcice anything different about these contol arms?
I want to see the replies before I tell what it is.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
07-27-2009, 04:46 PM | #2 |
Re: You Boys notcice anything different about these contol arms?
OH it is a 68 truck frame, actually the frame I'm gunna use for my truck here soon.
07-27-2009, 04:50 PM | #3 |
Watch out for your cornhole !
Nothing wrong with those arms. I wouldn't trust the guy who installed them though
07-27-2009, 04:56 PM | #4 |
On the fast track to nowhere..
Trying to center the wheels in the fenders the easy way?
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
07-27-2009, 05:01 PM | #5 |
Good eye but not why. It was actually done that for a reason, but it wasn't to center the wheel in the fender well.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! Last edited by BarryB; 07-27-2009 at 05:01 PM. |
07-27-2009, 05:31 PM | #6 |
Swapped the left and right ball joints?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
07-27-2009, 05:33 PM | #7 |
I'm sure it gave a ton more caster in alignment.
07-27-2009, 09:21 PM | #8 |
Well I'd better post it up before it gets lost in the archives in this forum.
The PO that I purchased this from, swapped the passenger and drivers upper a-arms to there opposite sides. NOW, the reason, doing this he says, sets the caster back 9 degrees IIRC. and doing that will keep more of the tread on the raod when in a turn. Have you ever noticed an older car when its under a sharp turn the one front wheel looks like it only has an inch or wo of tire grabbing the road. With setting your caster back, it actually keeps the tire flatter and more tread on the road. So basically you can kick the rearend around and the front will stay planted. And with my just moving the fram around I can see what exactly he was talking about. It's a cheap and easy suspension trick.
07-27-2009, 09:32 PM | #9 |
Tot Roddin'
I was going to guess the arms were on the opposite sides...
That's a new one for me about the caster changes.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
07-27-2009, 10:34 PM | #10 |
Phone's ringin Dude.
Interesting
I pitty the fool with only two headlights!! 2003 SILVERADO SS--THE NEW GIRL 1972 GMC--THE OLD GIRL |
07-27-2009, 11:13 PM | #11 |
Green club
This has been brought up before, I don't kow if anyone has posted with real world results or experiences yet
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears 70 SS396 Chevelle 427/200-4R/3.73posi 61 Lincoln Continental, black on black Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln |
07-28-2009, 12:05 AM | #12 |
well this was a running driving truck before I yanked the frontend, and cab off it. The PO said it does take some getting used to driving it. I know I need to hurry up and get it back on the road so I can give you a " real world" experience.
07-28-2009, 12:12 AM | #13 |
I just ordered a grand worth of front suspension stuff and will be interested if any one else has tried this trick with positive results. Since I will have the spindels off and the brakes out this would be easy to swap them around. I wonder though if the aftermarket UCA's have this greater caster angle already built into them?
07-28-2009, 12:57 AM | #14 |
Saving 1 truck at a time!
These trucks...all trucks are light in the rear..."loose" in circle track terms. So why would you want the front end to be "tight" (over steer) and grab more? It will make the rearend problem worse?
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
07-28-2009, 12:57 AM | #15 |
My Carbon Footprint
The fact that the PO says that it does take some time getting used to driving makes me wonder.......most of the P.O.S.'s that I have owed with worn out suspension "took some time" getting used to driving cuz they were scary as hell to drive. In this case, what did HE mean??
07-28-2009, 11:02 AM | #16 |
It's the other way. Lots of caster makes the wheels want to stay running straight, which makes the steering much "heavier" feeling.
07-28-2009, 11:30 AM | #17 |
I stand corrected. I probably should have said "caster in the opposite direction" since he said it sets it "back" and not further back. If that configuration just increases the caster in the same direction I agree it would actually get a heavier feel. Also, I guess the front wheel on a bicycle is more like a car than a shopping cart is. I remember cutting the forks off an old bike and extending the front wheel by jamming them on the ends of the front forks. Really stable but harder to turn.
07-28-2009, 11:27 PM | #18 |
YOu boys hit it on the head. It did give it a "heavier" steering. But I actually like my steering to be on the heavier side.
Heck anybody have a truck that they can do it to to get a real experience. it shouldn't mess to much with the tow in or out. Try and let us no for sure. My truck is far from being roadworthy, or I would tell you.
07-29-2009, 12:10 AM | #19 |
Texas Big Wig
Looks to me like them being swapped like that makes the spindle lean forwards & in my mind that would make it a twitchy SOB
I know on my VW I added caster shims to help it handle better with the rake it has & they rotated the spindles rearward Correct me if Im wrong... |
07-29-2009, 02:37 PM | #20 |
If I get can get pics of the spindles I will but it is raining right now and has been all day. The spindle angles backwards with this swap.
