07-27-2009, 09:18 PM | #1 |
Bedsides ?
i have a wood bed and im going to take the wood out and put steel floor in
i was wondering if you can do this without changing the bedsides? Can you use wood bedsides with a steel bed? |
07-27-2009, 09:32 PM | #2 |
Tot Roddin'
Re: Bedsides ?
The only things you will have to change will be the front panel and the crossmembers. The bedsides will work perfectly as will the wheels tubs.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 07-27-2009 at 09:33 PM. |
07-27-2009, 09:33 PM | #3 |
Re: Bedsides ?
i am in the process of doing the opposite, steel to wood. the bedsides can be used with both but u will need to change the front bed panel. an adapter is also sold that can be welded on.
1967 C-10 Project 2008 Suburban 2017 GMC Sierra |
07-27-2009, 09:39 PM | #4 |
Re: Bedsides ?
Yes the bedsides are the same. the front header panel is different and rear cross sill is different but that should be with the steel floor when you get it.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
07-27-2009, 09:47 PM | #5 |
Re: Bedsides ?
awesome thanks for the tips
i already have the front piece. the crossmembers will have to changed over from the steel bed. you cant put the steel floor onto the wood beds crossmembers? |
