Old 07-28-2009, 09:32 AM   #1
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
cab corner /rocker replacement $$$
What is a ball park figure to have these items replaced? I am looking at a truck that is in need of repair in these areas and luckily both my other trucks have not had this type problem.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 07-29-2009, 01:14 AM   #2
mclairmo
Re: cab corner /rocker replacement $$$
A lot to do it right. It would be much cheaper for you to take a welding class at your local community college, buy a small mig welder and do it yourself. I do all my own welding now and it saves a ton of money. Mig welders are not expensive andnot hard to use, just takes practice.
mclairmo is offline   Reply With Quote
Old 07-29-2009, 01:23 AM   #3
epashhans
epashhans's Avatar
Are you using flux core or gas? Flux core welders are cheeeeap. Just more splatter...
'67 C-10 Shorty - 454, 5spd, and speed holes!
epashhans is offline   Reply With Quote
Old 07-29-2009, 07:19 AM   #4
mrein3
mrein3's Avatar
I did both of my rockers myself. The first one cost $1020. About $900 for a good Miller 220V welder, $60 for a community college evening welding class, approximately $40 for shop supplies, and $20 for a shipped aftermarket rocker.
The 2nd one cost me $20 and I get to keep the welder.
I've had this welder for about 5 or 6 years. It is invaluable in the shop. Until this past spring I never used flux core wire in it. This spring I helped a very good friend put back together a rusted out dock frame. Since we did the work outside we had to use flux core. Let me tell you I'll never use that on sheet metal body work. What a mess.
To use solid wire with a gas shield you HAVE to be inside. If you are outside the wind will blow away your shield and leave the weld puddle to oxidize in the atmosphere. The flux in the core of flux core wire is there to vaporize and create a sheild when you are welding in a place where you can't use a shield gas. This vaporized flux protects the weld puddle from the atmosphere but leaves a residue you need to clean up plus there is a lot more splatter from the weld puddle that gets on your work.
Half way through the dock project my friend bought one of these 110V cheapo welders from Menards. Lets just say it works ok. There is no comparison between my Miller and his unit.
In summary, I would learn how to weld. Rockers are about the easiest thing you can do for your first job. If you search this site you will see detailed threads with pictures on how to remove and replace a rocker.
And stick with a name brand welding machine. Purchase it from a welding supply house. Those guys will be there when you need your gas tank filled and/or need more consumables for your machine. Plus they can answer questions that the kid at Menards or Home Depot doesn't have business answering.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 07-29-2009, 03:11 PM   #5
purewhitemp5
Welding classes in my area cost about $320 and my millermatic 211 MVP cost me about $970 shipped.
purewhitemp5 is offline   Reply With Quote
Old 07-29-2009, 03:17 PM   #6
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
I was really looking at what a typical shop might charge. Thanks for the info.
Old 07-29-2009, 03:47 PM   #7
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
Arrow Re: cab corner /rocker replacement $$$
you know we have not answered your original question and to be honest I DONT KNOW ? shop's charge HIGH $ for stuff like this , most people just do it themselve's ,
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
Old 07-29-2009, 03:21 PM   #8
Sinister
Between Trucks...
Sinister's Avatar
A shop is going to charge you enough to where the better deal is to get a welder and do it yourself. You don't need to take a class, just practice on scrap. Plenty of online welding tutorials.
http://www.mig-welding.co.uk/
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 07-29-2009, 03:43 PM   #9
19673ontree
CAN'T FIX NOTHIN
Talking Re: cab corner /rocker replacement $$$
well I guess I am REALLY CHEAP !!!!!!!!!!!
I never figured I could afford a mig welder cause if I had one I WANT A GOOD ONE ! and like I said I can't afford it so here is what I use , the eastwood company stitch welder it work's off a normal arc welder set to the lowest setting , I put my rocker's and cab corner's in with this tool , it is easy to use and CHEAP!!!!!!!!!!!!!!!!!!!!!!! $70 BUCK's
now before someone jump's up and say's A MIG IS BETTER ! I KNOW THAT !
BUT A STITCH IS CHEAPER
http://cgi.ebay.com/ebaymotors/Eastw...271710005r8911
underdash AC
Old 07-29-2009, 03:42 PM   #10
Chada
I am working on my first project with a friend who has a welder and he has given me a few lessons. We took the cab off the truck and replaced the four cab supports, inner rockers, cut free and re-welded one of the outer rockers and patched the cab floor in around two days. Really was not hard at all. Just buy or rent a welder its not that hard.
Chada is offline   Reply With Quote
Old 07-29-2009, 03:58 PM   #11
BarryB
BarryB's Avatar
A typical shop charges by the hour depending on where ytour located, is how much an hour it is. Iwould say 16 hours, at 35-50 an hour. So thats an idea of what you'd should be expecting to pay.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 07-29-2009, 04:00 PM   #12
BarryB
BarryB's Avatar
Oh forgot to add, get the better quality replacement pieces so fitment won't be all that hard some of the lesser grade, cost more in the long wrong.
Two rules in life.
Old 07-29-2009, 04:01 PM   #13
Ackattack
Ackattack's Avatar
$50/hr x 12 hours = $600.....I'm guessing on time.
Ackattack is offline   Reply With Quote
Old 07-29-2009, 04:01 PM   #14
gcburdic
Restoration Virgin!
gcburdic's Avatar
PM sent.....also, I was one of those that let someone else do them for me....(not b/c I am rich, but b/c I had no clue what I was doing)...don't know how much just the rocker replacement cost me, but you could estimate $50-$60/ hr labor......
FYI...I do intend on taking a welding class or if there is a local guy that wants to teach a young whipper snapper like me, I would be willing to dance at your next wedding!!!LOL
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 07-29-2009, 04:10 PM   #15
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Thanks this gives me an idea. To me $600-800 to fix all the rust issues on a $600 truck does not seem too bad.
Old 07-29-2009, 04:13 PM   #16
mclairmo
I use gas (Argon to be exact) and do all welding inside away from the wind. I have a cheap 110V Cebora made in Italy I think and it works fine. I won't trust a body shop since most are awful. And, if you find a good one they may charge you an arm and a leg.
Old 07-29-2009, 05:44 PM   #17
ebfabman
With bodywork, you generally get what you pay for.
ebfabman is offline   Reply With Quote
Old 07-29-2009, 06:11 PM   #18
mbgmike
Yeah we do this for a living and like said you get what you pay for. Most guys don't want to pay anything and think shops are too high. If you give them a low price then others think your too cheap and go somewhere else. We decided to just be high on price and if they go somewhere else so be it. I have seen plenty of the DIY's jobs
mbgmike is offline   Reply With Quote
Old 07-29-2009, 06:14 PM   #19
ebfabman
"......I have seen plenty of the DIY's jobs "
You can spot those a mile away!
Old 07-29-2009, 06:22 PM   #20
Bam Bam 56
Actually for the welder i picked up a 110v Millermatic 135 a few years ago and love it. it gets excellent penetration for a 110v welder and it has a very low setting that works awesome for body work. I think i paid about $500 for it. I have been using it on my race cars ever since i got it and even rebuilt the rear stubs with it
Chris "Bam Bam" Shields
Little Chute, WI
1970 Chevy Longhorn C20 in progress
2007 Chevy Vortech MAX - every day beast
Project Longhorn
Bam Bam 56 is offline   Reply With Quote
